Show/Hide Dependent Fields Plus
| Name: | Show/Hide Dependent Fields Plus | |
| Version: | 0.96 (Released: Apr 25, 2019 - changelog) | |
| Requires: | CMS Builder v3.00 | |
| Author: | Cy Morris | |
| Price: | Free | |
Allows customization of which fields appear or disappear when a key field changes or an option is selected. Based on Show/Hide Dependant Fields 0.03 by Chris, but with more capabilities. See code for more info.
Allows customization of which fields appear or disappear when a key field changes or an option is selected. Based on Show/Hide Dependant Fields 0.03 by Chris, but with more capabilities. Use any field that fires a change event (text, textarea, select, checkbox, radio). Changes cascade, so if a field is hidden and it has rules, those elements are hidden too.
NOTE: To add support for hiding separators, you must add a small modification to the cmsBuilder core code (see readme file).
Customer Quotes
This is really a great plugin we use is a lot for many things like forms in cmsb or email template generators.
Maurice Kuhr
Dropmonkey
This is a wonderful add-on that provides unique / variable solutions to customize section editors and make it easy to show and hide editor fields, thereby providing the ability to hide more complex fields that do not require daily access - yet show only the fields that are managed on a more regular basis.... Making for a very clean and simple appearance.
Michael Habenicht
Maurice Kuhr
Dropmonkey
Dropmonkey
Michael Habenicht
