Setting a custom search....
20 posts by 2 authors in: Forums > CMS Builder
Last Post: January 18, 2008   (RSS)
Re: [jimbly2] Setting a custom search....
By Dave - January 7, 2008
Sure, no problem.
The .= operator means "add to the end" or "append" so you're likely getting those errors because you're trying to add to a variable that hasn't been defined yet. Try defining $where with a blank value first like this so it's defined:
$where = "";
Then, you can use an if statement to assign a default value if there is no type defined. Like this:
if ($type == "") { $type = "Ventures"; }
Hope that helps, let me know if you need more detail.
Re: [Dave] Setting a custom search....
By jimbly2 - January 7, 2008
still can't seem to get rid of the undefined variables....here's what I have now:
require_once "C:/inetpub/wwwroot/camco_php/cmsAdmin/lib/viewer_functions.php";
$options = array(); // NOTE: see online documentation for more details on these options
// get page number and keywords
$pageNumber = @$FORM['page'] ? $FORM['page'] : 1;
$country = @$FORM['location'];
$type = @$FORM['type'];
// create custom where query
$type = "Ventures";
if ($country) { $where .= "" .escapeMysqlString($country). "'"; }
if ($where && $type) { $where .= ""; }
$options['tableName'] = 'jobs'; // (REQUIRED) MySQL tablename to list record from. Example: 'article';
$options['titleField'] = 'title'; // (optional) MySQL fieldname used in viewer url for search engines. Example: 'title' would display: viewer.php/article_title_here-123
$options['viewerUrl'] = 'jobsPage.php'; // (optional) URL of viewer page. Example: '/articles/view.php';
$options['perPage'] = ''; // (optional) The number of records to display per page. Example: '5'; Defaults to 10.
$options['orderBy'] = 'title'; // (optional) Fieldnames to sort by. Example: 'field1, field2 DESC, field3';
$options['pageNum'] = $pageNumber;
$options['where'] = $where;
$options['useSeoUrls'] = ''; // (ADVANCED) Set this to '1' for search engine friendly urls: view.php/123 instead of view.php?123 (not supported on all web servers, and viewerUrl must be absolute path such as '/path/viewer.php')
list($listRows, $listDetails) = getListRows($options);
// update page links
$pageLink = "{$_SERVER['PHP_SELF']}?country=" .urlencode($country). "&type=" . urlencode($type);
$listDetails['prevPageLink'] = "{$pageLink}&page={$listDetails['prevPage']}";
$listDetails['nextPageLink'] = "{$pageLink}&page={$listDetails['nextPage']}";
$listDetails['firstPageLink'] = "{$pageLink}&page=1";
$listDetails['lastPageLink'] = "{$pageLink}&page={$listDetails['totalPages']}";
...which bit have I got wrong?
Jim
Try replacing this:
$type = "Ventures";
with this:
// set default type
$where = "";
if ($country) { $where .= "location = '" .escapeMysqlString($country). "'"; }
if ($where && $type) { $where .= " AND "; }
if ($type) { $where .= "type = '" .escapeMysqlString($type). "'"; }
Let me know how that works out.
..no joy - still returns this:
Notice: Undefined variable: where in C:\inetpub\wwwroot\camco_php\careers_ventures.php on line 288
Notice: Undefined variable: where in C:\inetpub\wwwroot\camco_php\careers_ventures.php on line 289
No records were found!
These are lines 288/9:
Help! Thnx :-)
And you have this above those lines?
$where = "";
Can you just attach the viewer (careers_ventures.php) to your post and I'll run it locally and have a look.
Hi - sorry - once I put that back in above it's working fine -
Thanks for your help!
best,
Jim
By jimbly2 - January 10, 2008
on the same topic of setting up a custom search, I'd like to have a search option at the top of the page that displays the Press releases - so people can search through them. Is this hard to do?
Jim
By Dave - January 10, 2008
So you want like a "keyword" field? What press release fields do you want searched for the keyword? (title, content, etc?)
It shouldn't be that hard at all. It's very similar to how we did the other search fields. Let me know the fields you want searched and I'll write something up for you.
Yes - thats exactly what I need - the fields to search would be:
Title, Depeartment. Location and Date
Thanks Dave :-)
