Categories and records grouped on same page
17 posts by 4 authors in: Forums > CMS Builder
Last Post: May 13, 2009   (RSS)
By ross - May 6, 2009
Hi Pete.
I'll see what I can do for you. Can you post a copy of the actual template file you are working with as well? Are both your sections using the same schema? If they aren't, post up a copy of your other schema file and we'll go from there.
Ross Fairbairn - Consulting
Re: [ross] Categories and records grouped on same page
By petejdg - May 6, 2009 - edited: May 6, 2009
Here is my template - I have a sample category header and record above my coding.
Hi Pete.
There isn't anything attached :). Could you try again?
By petejdg - May 11, 2009
Ross,
did you happen to come up with anything yet? I have messed some more but am very stuck. Obviously I don't know much php.
pete
By ross - May 13, 2009
Hi Pete
Thanks for hanging on :).
I think you might actually be looking for something a little different than this thread is dealing with.
To me, it sounds like what you need is a list of all your staff but organized by category. To get something like that, try out this test code:
<?php $lastCategory = ''; ?>
<?php foreach ($our_staffRecords as $record): ?>
<?php if ($lastCategory != $record['category']): ?>
<h1><?php echo $record['category'] ?></h1>
<?php endif; ?>
First Name: <?php echo $record['fname'] ?><br/>
<?php $lastCategory = $record['category']; ?>
That will give you a heading for each category and then display the names of each person. You can add in more fields to display if you like or change the formatting. Basically though, the code is checking what the current category name is. If it's the same as the last one it displayed, then it just keeps going. If the current category is different from the previous one, it displays the category name.
What you'll need to do is make sure in your viewer code at the top of the page, you have
'orderBy' => 'category DESC',
You need to sort the list by the category.
Give this a shot and let me know how you make out. Thanks!
By petejdg - May 13, 2009
That is awesome! It works sweet. Sorry - I just didn't want to bug you too bad on this one. Thanks so much for helping me out.
