category listing end code help needed
Last Post: August 9, 2009   (RSS)
By craig_bcd - August 9, 2009
Hey everyone -
I am using categories on a page that lists links. I have figured out how to list the categories and the items under the categories but I need an if statement that says, if this is the last item in the category, put in the "back to top" statement below.
I must be having a mental block because I cannot see how to determine it is the last record in the category. I think it is an "if" statement I need but i just can't get it. Any help would be appreciated.
The page is here: http://www.marcushoffman.com/links.php
Here is the back to top code:
<p class="back_top"><a href="#top">back to top ^</a></p>
Here is the code on the page I have so far:
<?php echo $links_introRecord['content'] ?>
<?php $lastCategory = ""; ?>
<?php foreach ($linksRecords as $record): ?>
<ul>
<li><a href="#<?php echo $record['category'] ?>"><?php echo $record['category'] ?></a></li>
</ul>
<?php if (!$linksRecords): ?>
No records were found!<br/><br/>
<?php if ($record['category'] != $lastCategory): ?>
<?php $lastCategory = $record['category']?>
<br/>
<a name="<?php echo $record['category'] ?>"></a><h2><?php echo $record['category'] ?></h2>
<p><a target="_blank" href="<?php echo $record['link'] ?>"><?php echo $record['title'] ?></a></p>
Re: [craighodges] category listing end code help needed
By Chris - August 9, 2009
Hi craighodges,
With that approach, I think the easiest solution involves two if statements:
(New code shown indented)
<ul>
</ul>
<?php if ($lastCategory !== ""): ?>
<?php endif; ?>
<br/>
Hope this helps!
Re: [chris] category listing end code help needed
Chris - that is terrific - exactly what I need! I chose the first method but I like the second one better from a programming status.
I love cmsb! It has made my life (and my customers lives) so much better.
Thanks again.
Craig
