Echo details from another section??
36 posts by 5 authors in: Forums > CMS Builder
Last Post: May 31, 2010   (RSS)
By (Deleted User) - October 1, 2009
This is exactly the reason why I wish I had moved over to interactive tools earlier in my web life! I did the above and guess what - of course it only goes and works perfectly!
THANK YOU so much - I don't know any other company who will write plugins and how-to guides to help its customers. I know where I'll be coming when my next site commission comes through - YOU!
Jono
By (Deleted User) - October 2, 2009
This is great and has so far reduced quite a large page by about 300 lines of if commands and code.
Using the same principle am I able to do the following:
On a tour there are a list of bikes available. There is a default bike included in the tour price - that's fine I can use the list from the database method.
There are more bikes available for each tour but with an upgrade price.
At the moment I have a textfield for each bike. If that bike is available for upgrade a price is entered in the text field.
Then on the tour page I use a load of if commands to display any bike and it's price if it has been entered - if no price has been entered in the text field nothing shows.
I love the idea of your list options but can't work out how it would show only if something has been entered - can you help?
Thanks again,
Jono.
Re: [jonoc73] Echo details from another section??
By Chris - October 5, 2009
Hi Jono,
That's a tricky problem!
Are the "bike upgrade prices" completely customizable for each tour, or could they be calculated (e.g. bike.price minus tour.default_bike_price)?
By (Deleted User) - October 5, 2009
Hi Chris,
I'm afraid it's different for each tour. I have a list of about 23 bikes. The upgrade price for each bike can indeed be different depending on what tour.
At the mo I just textfield list all the bikes individually and us loads of if commands to show the bike logo and price if anything is entered in it's textfield. It works but I can't help feel this is a very long way round.
Thanks for all your help still,
Jono
By (Deleted User) - October 8, 2009
Hi, I am using the Related Record Lookup Functions Plugin and it works really well.
However I get a MySQL error when nothing is selected for one of the fields, this is understandable as it's trying to list something that isn't there.
How can I get it to ignore that Lookup Related field function if nothing is entered?
Jono.
By Chris - October 8, 2009
Hi Jono,
Can you please post the exact error you're getting?
Hi, It's:
MySQL Error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ')) ORDER BY title' at line 3
Thanks Jono
By Chris - October 11, 2009
Hi Jono,
I think I've fixed that bug. Can you try this new version please?
If you're still getting the error (or get any other errors) please let me know!
By (Deleted User) - October 11, 2009
Yep, this newer function version works a treat - THANKS.
J
