URGENT - Unable to access CMSB
Last Post: January 4, 2010   (RSS)
The error message is:
"Unable to start another process
Maximum number of processes reached, refreshing in 10 seconds."
As far as I am aware, no one else is accessing this CMSB. The games are scheduled to start in 30mins and I am locked out!!
Re: [terryally] URGENT - Unable to access CMSB
By Dave - January 2, 2010
Hi terryally,
Glad it's working again!
I'd recommend checking with your host and see if you can find out what the process limit is and what the hung process or script was.
Re: [Dave] URGENT - Unable to access CMSB
The limit is 20 concurrent processes. I am only running CMSB with PHP5. Not even a straight mysql command.
It appears that the script on the news page was not exiting correctly.
I'll monitor and if the problem occurs during the period I'll ask admin to terminate sessions. Afterwards, I'll have time to investigate it.
Regards
Terry
By Dave - January 4, 2010
Hi Terry,
Ok, let me know if you find anything else. PHP should automatically exit when the page is finished being output so their shouldn't be a problem there (unless you have some custom code that takes a long time to run).
The other scenario would be if you had 21+ people all trying to load your web page at the same time then you'd get that error (or 11+ if PHP isn't running as an apache module since each Apache and PHP would require a process for each page view).
