Display problem with VIEW URL
Last Post: February 2, 2010 (RSS)
I am including a database entry on the page
http://www.lakesidesurrey.co.uk/lcc_eventdetails.php and it works fine but when this is used as a VIEW URL the inclusion does not display.
To see what I mean view:
http://www.lakesidesurrey.co.uk/lcc_eventdetails.php first and then
http://www.lakesidesurrey.co.uk/lcc_eventdetails.php?Mother-s-Day-lunch-and-show-8
Can you tell me how to rectify this please?
Terry
P.S. if you click on an event link from http://www.lakesidesurrey.co.uk/home.php it will use the above template to display the details.
Terry
Re: [terryally] Display problem with VIEW URL
By Chris - January 29, 2010
Hi Terry,
Can you please post the complete PHP source code for that page?
Re: [chris] Display problem with VIEW URL
Hi Terry,
The main page code follows immediate and below that are the codes for the two sidebar inserts starting at line 114.
MAIN PAGE:
<?php header('Content-type: text/html; charset=utf-8'); ?>
require_once "/home/lakeside/www/www/lcc_cmsadmin/lib/viewer_functions.php";
list($showsRecords, $showsMetaData) = getRecords(array(
'tableName' => 'shows',
'where' => whereRecordNumberInUrl(1),
$showsRecord = @$showsRecords[0]; // get first record
// show error message if no matching record is found
if (!$showsRecord) {
header("HTTP/1.0 404 Not Found");
print "Record not found!";
exit;
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
<head>
<title><?php echo $showsRecord['event_title'] ?></title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7"/>
<link rel="stylesheet" type="text/css" href="/lcc_css/all.css"/>
<!--[if lt IE 7]><link rel="stylesheet" type="text/css" href="/lcc_css/lt7.css" media="screen"/><![endif]-->
<script type="text/javascript" src="lcc_js/swfobject.js"></script>
<script language="javascript" src="x_core.js"></script>
<script language="javascript" src="ylib.js"></script>
<script language="javascript" src="y_tabs.js"></script>
<script language="javascript">
var arrayHeaders = ["tab-header1","tab-header2","tab-header3"];
var arrayContents = ["tab-content1","tab-content2","tab-content3"];
window.onload = function(){
var tabRelationship =
new ylib.widget.Tabs(arrayHeaders, arrayContents, 0);
</script>
<link rel="stylesheet" type="text/css" href="lcc_css/contentslider.css" />
<script type="text/javascript" src="contentslider.js">
</script>
</head>
<body>
<div id="pattern">
<div id="header-area">
<div id="header">
<div id="header-flash">
<object type="application/x-shockwave-flash" data="header.swf" width="1040" height="240">
<param name="movie" value="header.swf" />
<param value="transparent" name="wmode" />
</object>
<div id="wrapper">
<div id="main-t"> </div>
<div id="main">
<div id="content">
<h2 class="lakeside"><?php echo $showsRecord['event_title'] ?></h2>
<div id="content-c2">
<b>Date:</b> <?php echo date("l j M Y", strtotime($showsRecord['start_date'])) ?><br/><br/>
<b>Cost:</b> <?php echo $showsRecord['cost'] ?><br/><br/>
<b>Doors open: </b><?php echo $showsRecord['doors_open'] ?><br/><br/>
<?php if ($showsRecord['dinner_starts']): ?>
<b>Dinner starts: </b><?php echo $showsRecord['dinner_starts'] ?><br/><br/>
<?php if ($showsRecord['show_time']): ?>
<b>Show time: </b><?php echo $showsRecord['show_time'] ?><br/><br/>
<?php if ($showsRecord['show_ends']): ?>
<b>Show ends:</b> <?php echo $showsRecord['show_ends'] ?><br/><br/>
<?php if ($showsRecord['venue']): ?>
<b>Venue:</b> <?php echo $showsRecord['venue'] ?><br/><br/>
<?php if ($showsRecord['food']): ?>
<b>Food & beverage</b>: <?php echo $showsRecord['food'] ?><br/><br/>
<?php if ($showsRecord['notes']): ?>
<EM><?php echo $showsRecord['notes'] ?></EM><br/><br/>
<br/><br/>
<a href="mailto:?subject=<?php echo thisPageUrl() ?>">Email this Page</a>
</div><?php ?>
<div id="content-b"> </div>
<div id="sidebar">
<!-- START SPECIAL FEATURED EVENTS MAX TWO 240PX WIDE AND VARIABLE LENGTH-->
<div class="banner">
<?php include "/home/lakeside/www/www/lcc_inc/featured_event1.inc.php" ;?>
<div class="banner02">
<?php include "/home/lakeside/www/www/lcc_inc/featured_event2.inc.php" ;?>
<!-- END SPECIAL FEATURED EVENTS MAX TWO 240PX WIDE AND VARIABLE LENGTH-->
</div><?php ?>
</div><?php ?>
<?php include "/home/lakeside/www/www/lcc_inc/footer.inc.php" ;?>
</div><?php ?>
</div><?php ?>
</div><?php ?>
</body>
</html>
FEATURED_EVENT1
list($featured_event_1Records, $featured_event_1MetaData) = getRecords(array(
'tableName' => 'featured_event_1',
$featured_event_1Record = @$featured_event_1Records[0]; // get first record
<?php foreach ($featured_event_1Record['featured_image'] as $upload): ?>
<?php if ($upload['hasThumbnail']): ?>
<a href="<?php echo $featured_event_1Record['_link'] ?>" title="<?php echo $featured_event_1Record['title'] ?>" ><img src="<?php echo $upload['thumbUrlPath'] ?>" width="<?php echo $upload['thumbWidth'] ?>" height="<?php echo $upload['thumbHeight'] ?>" alt="<?php echo $featured_event_1Record['title'] ?>" border="0" /></a><br/>
<?php elseif ($upload['isImage']): ?>
<a href="<?php echo $featured_event_1Record['_link'] ?>" title="<?php echo $featured_event_1Record['title'] ?>" ><img src="<?php echo $upload['urlPath'] ?>" width="<?php echo $upload['width'] ?>" height="<?php echo $upload['height'] ?>" alt="<?php echo $featured_event_1Record['title'] ?>" border="0" /></a><br/>
<a href="<?php echo $upload['urlPath'] ?>">Download <?php echo $upload['filename'] ?></a><br/>
</a>
<?php if (!$featured_event_1Record): ?>
<a href="http://www.lakesidesurrey.co.uk/lcc_events.php" title="More shows">See more shows</a><br/><br/>
FEATURED_EVENT2:
list($featured_event_2Records, $featured_event_2MetaData) = getRecords(array(
'tableName' => 'featured_event_2',
$featured_event_2Record = @$featured_event_2Records[0]; // get first record
<?php foreach ($featured_event_2Record['featured_image'] as $upload): ?>
<img src="<?php echo $upload['thumbUrlPath'] ?>" width="<?php echo $upload['thumbWidth'] ?>" height="<?php echo $upload['thumbHeight'] ?>" alt="" /><br/>
<img src="<?php echo $upload['urlPath'] ?>" width="<?php echo $upload['width'] ?>" height="<?php echo $upload['height'] ?>" alt="" /><br/>
</a>
<?php if (!$featured_event_2Record): ?>
By Chris - February 1, 2010
Hi Terry,
Your featured event includes are using the record number of the request to select records. Can you try removing this line in both your featured event includes?
I hope this helps! Please let me know if you have any questions.
// FEATURED_EVENT1
That did the trick Chris. Merci beacoup.
