Property Types with Subtypes, "We also have ..."
16 posts by 3 authors in: Forums > CMS Builder
Last Post: April 9, 2010   (RSS)
By (Deleted User) - March 1, 2010
Just starting my first website using CMSB, and, far from taking pity on me, the client has asked me to do a highly complex setup. I have 2 questions ...
1) The client has asked for property types under the following scheme:
...snip...
RETAIL
High Street
Retail Warehousing
INDUSTRIAL
Retail Warehousing
Office & Storage
Factories
HOTELS & BARS
Pubs
Restaurants
Take Aways
Guest Houses, B&B's
Hotels
... snip..
As you can see, there are types and subtypes. Properties will only be assigned to subtypes. Some subtypes are repeated in different types (RETAIL & INDUSTRIAL for example both have a Retail Warehousing subtype).
Is this structure possible to create? I would like to know before I try to puree my brains trying to figure it out.
Why do we need this structure? Because of requirement 2.
2) There are a limited set of main property locations.
Town 1 City Center
Town 1 Suburbs / Business Parks
Town 2
Town 3
Everywhere else in County
On the results listing page, where a client has searched for Pubs in Town2, he would like a sidebar with:
You are viewing
Pubs in Town2
We also have Pubs
in Town 1 City Center(7),
Town 2(3)
.... etc.
Also in Town 2
Restaurants(2)
Take Aways(1)
Hotels(3)
Note that Guest Houses, B&B's did not appear, because in the example, there are none available in Town 2
Ie, first list locations where [subtype] is available in other locations, then list other [subtypes] in current location.
I hope this is clear? It's clear to me what the client wants, but when I try to see how to do this, all I see is mud :(
rgds
Alan
Re: [AlanMacDonald] Property Types with Subtypes, "We also have ..."
By Chris - March 2, 2010
Hi Alan,
That is a little complicated for a first CMSB project, yikes!
A Category Menu will solve your first requirement. When you create a section, you'll find Category Menu under <Advanced Menus>. Create one called "Property Types" and fill it with your types and subtypes.
You'll also want two Multi Record sections: "Locations" and "Listings".
Your Listing records will need to point to both a Location and a Property Type. Add two "list" fields to the Listings section:
Field Label: Location
Field Name: location
Field Type: list
Display As: pulldown
List Options: Get options from database (advanced)
Section Tablename: "locations"
Use this field for option values: "num"
Use this field for option labels: "title"
Field Label: Property Type
Field Name: property_type
Field Type: list
Section Tablename: "property_types"
Use this field for option labels: "breadcrumb"
Try creating some locations and listings and make sure everything works properly.
Let me know when you've gotten this far, then we'll tackle your search page with counts for "similar" searches.
By (Deleted User) - March 29, 2010
I'm back :)
Okay, got this working, and I can see how it works, which is a bonus :)
Only thing is, the output on the list page viewer and detail page viewer is coming out as
---------8<-------------snip
Title: First Property
Property Type: 12
Any way to replace the numbers there with the actual items from the list, in this case
Property Type: INDUSTRIAL : Office & Storage
I had a look at the CMSB cookbook and Multi Level Category Functions post (http://www.interactivetools.com/forum/gforum.cgi?post=64259) but could not see it.
Alan
By (Deleted User) - March 30, 2010
OK, I've got the first one myself, managed to get the property type.
// locate in the property_types category, the property type of the
// current record.
list($categoryRecords, $selectedCategory) = getCategories(array(
'tableName' => 'property_types',
'selectedCategoryNum' => $propertiesRecord['property_type'],
'categoryFormat' => 'showall', // showall, onelevel, twolevel
Property Type: <?php echo $selectedCategory['name'] ?>
but when I try similar code for the location, it does not work
list($locationsRecords, $locationsMetaData) = getRecords(array(
'tableName' => 'locations',
'where' => $propertiesRecord['location'],
$locationsRecord = @$locationsRecords[0];
Basically, each property has a location, the locations are set up as a multi-record. I know the number of the location for the current property, n, so how do I get the n'th record on the locations multi-record?
I'm sure it's simple, I just can't get my head around it.
and I got the second one too.
I dunno, posting here really crystallises the thinking!
'where' => 'num = "'.$propertiesRecord['location'].'"',
I'm just wondering - is all this stuff dealt with in some documentation I am not aware of? Can anyone point me to a good place to start?
I've looked at the online help, and the CMSB cookbook.
By Chris - March 30, 2010
Hi Alan,
Glad you got everything figured out! :D
We're currently trying to come up with simpler ways to "join" data from related records, so no, this isn't documented yet. Once we figure something out that we like (and that everyone will like too) I'll probably post a tutorial here in the forums.
Please let me know if you have any questions.
Re: [chris] Property Types with Subtypes, "We also have ..."
By (Deleted User) - April 6, 2010
OK, how do we perform searches on these criteria as set up above? Going slightly nutty here.
We have property types, and locations.
We want to be able to search for a set of property types, and list those properties in a single location.
How do you set up OR and and AND searching?
User would choose
Types
INDUSTRIAL : Retail Warehousing
Location
Town 2
The search needs to be (INDUSTRIAL : Retail Warehousing OR INDUSTRIAL : Office & Storage) AND Town 2
i.e., they need to be able to check a set of boxes for what type of property they are looking for, and then a location.
I just can't see it myself. :(
By Chris - April 6, 2010
Hi Alan,
CMS Builder does simple searching automatically (unless you ask it not to,) but you'll need a little extra code to get the OR part working.
Let's start with the simple search:
Create a form which will submit to your listing page. Add a dropdown for your locations and checkboxes for property_types:
<form action="listings.php" method="POST">
<option value="1">Uptown</option>
<option value="2">Downtown</option>
</select>
Property Type: <br/>
<input type="checkbox" name="property_type[]" value="1" id="pt1"> <label for="pt1">Residential</label><br/>
<input type="checkbox" name="property_type[]" value="2" id="pt2"> <label for="pt2">Commercial</label><br/>
</form>
The value="123" numbers will need to be the correct nums of the corresponding records. You could generate that form using PHP, but let's keep this explanation simple. :)
The location search will actually work right now, but you'll need to make a small change to your listing page to get the checkboxes to turn into an OR (which we'll accomplish by using MySQL's IN operator.) On your listings page, add this 'where' clause to your getRecords(), and the code above it:
$property_typeCSV = '';
if (@$_REQUEST['property_type']) {
$property_typeCSV = join(',', $_REQUEST['property_type']);
// load records
list($listingsRecords, $listingsMetaData) = getRecords(array(
'tableName' => 'listings',
'where' => $property_typeCSV ? ("property_type IN (" . mysql_escape($property_typeCSV) . ")") : '1'
I hope this helps. Please let me know if you have any questions.
By (Deleted User) - April 7, 2010
Thank you for that code - it worked perfectly. I had to temporarily make a lister for my property types, as the values were not what I expected, but once I had the correct values entered, off she flew.
I can now search
(type of property OR type of property OR ...) AND (Location)
This behaves correctly in all the tests I have tried.
Now, I am thinking out loud here, as it seems to help me work these things out.
Thanks to the wonder of Shifting Requirements (tm) I have to do:
Step 1 - Are you looking for a property to
[] Let [] Buy [] Either
Step 2 - What type of property?
Property types as checkboxes
Step 3 - Where do you want to search?
Property locations as a dropdown.
I am trying to think what is the best way to record the
To Let (AND/OR) To Buy
status of a property, and then allow searching on that status.
I could use a checkbox record, To-Let-chk and To-Buy-chk, and then use a simple javascript on the Either checkbox that simply sets both To Let and To Buy to selected. It could get horribly complicated if I decided to look at what happens if someone subsequently clicks again on a To Let or To Buy checkbox, but I am going to wilfully ignore that scenario.
That seems the simplest way to me. Does that solution make sense, or is there a better way?
By the way, I am completely ignoring the fact that I have the following fields in my database:
Sale Price
P.O.A. -- These two cover properties with a sale price, either explicit, or Price on Application which overrides any sale price
Rental Price -- the rental price, if any.
I am pretty sure that some very clever coding could be done to figure out the status of a property as to whether it is for sale, for rental, or both, based on the contents or empty state of these fields, but that is at a php/mysql guru level which I have nowhere near the experience points to approach!
