display a field value as "default value" for a texbox field (admin side)
Last Post: March 16, 2010   (RSS)
Let's say i have an editor "person"
Here are my fields that define "person"
name (text field)
age (text field)
description (text box)
I want to set for "descrition" as default value something like that :
"His name is $name and he is $age years old, please call this person"
I want this admin side, i know how to do it with a piece of PHP for a viewer page front side.
I've already tryed to put php code in the default value of my text area... without no result.
Can anybody help?
Re: [willbegood] display a field value as "default value" for a texbox field (admin side)
Hi willbegood.
Could you describe what you mean by "Admin side"?
Where do you want to view this information?
sorry but I still don't understand
Re: [gkornbluth] display a field value as "default value" for a texbox field (admin side)
see attachment for what i'm trying to do
image-2.png 157K
Do the values that you want to display come from another table?
no from the same table. I suppose there is a particular syntax to use, but don't know which one.
By Chris - March 15, 2010
Hi willbegood,
I don't think PHP alone could solve this, since the name and age fields are on the same web page as the description field. I think the only way to solve this would be with some custom JavaScript which dynamically updates the text field.
A simple alternative might be to literally use "$name" and "$age" in your description field, then replace them on the front-end:
$record['description'] = str_replace('$name', $record['name'], $record['description']);
$record['description'] = str_replace('$age', $record['age'], $record['description']);
echo htmlspecialchars($record['description']);
If you're set on having the textbox dynamically update, we could accomplish this via custom programming through our consulting service. Please let me know if you're interested in that.
I hope this helps. Please let me know if you have any questions.
Re: [chris] display a field value as "default value" for a texbox field (admin side)
Chris,
Thanks for fielding this one.
