Gallery Link Issue
Last Post: October 27, 2010   (RSS)
By KCMedia - October 23, 2010
I have setup a gallery and i am having issues when you click on the links to show other pages and galleries
this is the link to the page
http://www.awardbathrooms.com.au/awardwinningbathrooms.php
It will load the first page ok with the images but when you click on the links on the left it will not load all of the pages and i can not work out why.
also find attached the code for the pages.
thank you
Craig
Craig
KC Media Solutions
www.kcmedia.biz
Re: [kcmedia] Gallery Link Issue
Hi Craig,
Just a quick idea that you probably tried already, but sometimes the occurance of 'where' => whereRecordNumberInUrl(1), can trip up how pages are displayed.
Good luck,
By Jason - October 25, 2010
Hi Craig,
I believe Jerry is right. The problem seems to be here:
list($google_analyticsRecords, $google_analyticsMetaData) = getRecords(array(
'tableName' => 'google_analytics',
$google_analyticsRecord = @$google_analyticsRecords[0]; // get first record
You're using the whereRecordNumberInUrl() function, which worked fine on the first page when the record number was 1. If there isn't a record 2 in the google_analytics table, then this would be whey the page isn't loading.
If there is only 1 record in google_analytics that you want to pull out, try this code:
'allowSearch' => false,
This will just pull out the first record in that table.
You'll want to take a look at the other tables you're doing this on (gallery_metatags and gallery_wording) since you're trying to get these records all based on the same record number.
By Jason - October 26, 2010
Hi Craig,
There are a couple of things happening here. First, the only time you're selecting your galleries is in the query where you're selecting all you galleries to display the links.
When you're actually showing images, you're using the variable $record. The only place this is being set is in the foreach loop above it where you're outputting your galleries. You're probably finding that the images being displayed are always from "Gallery 2". This is because this is the last value $record had when in the foreach loop.
The first thing you need to do is get a variable with the gallery you want to display in it.
In awardwinningbathrooms.php add this highlighted code:
// load records
list($galleryRecords, $galleryMetaData) = getRecords(array(
'tableName' => 'gallery',
'limit' => '15',
'allowSearch' => 0,
// 'where' => whereRecordNumberInUrl(1),
$displayGallery = $galleryRecords[0];
And in awardwinningbathroomDetails.php add this highlighted code:
// load records
'limit' => '15',
'allowSearch' => true,
list($displayGallery,)=getRecords(array(
'limit' => 1,
$displayGallery=$displayGallery[0];
Finally, change your code where you're displaying your gallery like this (this should be the same on both pages:
<h2>Our <span>Gallery</span></h2>
<div> <!-- STEP 2a: Display Uploads for field 'images' (Paste this anywhere inside STEP2 to display uploads) -->
<!-- Upload Fields: num, createdTime, tableName, fieldName, recordNum, preSaveTempId, filePath, filename, extension, thumbFilePath, isImage, hasThumbnail, urlPath, width, height, thumbUrlPath, thumbWidth, thumbHeight, info1, info2, info3, info4, info5 -->
<?php foreach ($displayGallery['images'] as $upload): ?>
<a href="<?php echo $upload['urlPath'] ?>" rel="lightbox[screenshots]" ><img src="<?php echo $upload['thumbUrlPath2'] ?>" alt="" width="<?php echo $upload['thumbWidth2'] ?>" height="<?php echo $upload['thumbHeight2'] ?>" border="0" /></a>
<?php break ?>
<?php endforeach ?><br /><br />
<!-- STEP2a: /Display Uploads -->
<?php if (@++$count == 1) { continue; } ?>
<a href="<?php echo $upload['urlPath'] ?>" rel="lightbox[screenshots]" ><img src="<?php echo $upload['thumbUrlPath'] ?>" alt="" width="100" height="100" vspace="13" border="0" /></a>
Give this a try and let me know if you run into any other problems.
Re: [Jason] Gallery Link Issue
By KCMedia - October 26, 2010
Hi Jason
It is getting better but still not 100% when you go to the gallery page it will load images ok but when you click on the left hand side say gallery 2 it will load images but when you click on gallery 1 it will show the main image as gallery 2 image and not gallery 1 main image.
Craig
Craig
KC Media Solutions
www.kcmedia.biz
By Jason - October 27, 2010
Hi Craig,
On your page where you're displaying the main image, did you change the code to look like this:
<?php break ?>
If so and it's still not working, please attach your most recent versions of these files and I'll take a look.
Thanks.
By KCMedia - October 27, 2010
Hi Jason
Yes it is correct from what i can see.
Just to make sure we both on the right track.
When i first load the awarwinningbathrooms.php page it should show the thumbnail2 for the first gallery in the section and then when you click on the next gallery link or any other gallery for that fact that it should show that main image for that gallery on the awardwinningbathroomsDetail.php page and then when you click another gallery it should show its main image.
Craig
Craig
KC Media Solutions
www.kcmedia.biz
Hi Craig,
The change was made in awardwinningbathrooms.php but not in awardwinningbathroomsDetail.php.
In that file you need to make the same change to where the main image is displayed as follows:
<?php break ?>
Hi Jason
thanks for that 100% perfect now, one more CMS Builder website done and completed now hading over to client today for them to complete.
thank you very much.
Craig
Craig
KC Media Solutions
www.kcmedia.biz
