pagination on search results
8 posts by 2 authors in: Forums > CMS Builder
Last Post: June 10, 2011   (RSS)
By 4cdg - March 3, 2011
having a problem. when i send search results from a search form to a results page, the first page works great, then if i go to next page it shows all records.
any suggestions
Re: [4cdg] pagination on search results
By Jason - March 3, 2011
If you could attach the .php file you're working with and provide a url to an example, I can take a closer look for you.
Re: [Jason] pagination on search results
i have attached search.php and searchResults.php
you can see them at www.prosalvage.com/search.php
search_006.php 14K
searchresults.php 14K
By Jason - March 7, 2011
I haven't been able to recreate your issue. When I do a search for everything, I get two pages. Going to the second page doesn't only displays 3 results. Going back and forth between the two pages doesn't seem to cause an issue either.
Could you give me some more background on exactly what search you're doing when you encounter this problem?
By 4cdg - March 7, 2011
i can't duplicate the issue either.... I guess it works. thanks
By 4cdg - June 10, 2011
I have found the issue, with the pages discussed above. when you perform a search everything is fine until you go to page 2 of the search results, then it displays all the records on page 2. It only does this when i have pagination setup.
If i do a search for price min 15,000 and max 20,000 it returns 2 pages of results. I have is setup to list page 1, page 2 etc along with prev and next. if you click next it holds the search criteria. If you select page 2 it drops all the search criteria and shows all records.
You can view them live at http://www.prosalvage.com there is a quick search and http://www.prosalvage.com/search.php is the other search form. I am able to produce the error from these 2 searches.
I have attached the documents again also.
By Jason - June 10, 2011
The problem you're getting here is that on your individual page links, you're not maintaining your search query, which is why all your results are being displayed.
We can get around this by using some code Chris posted here:
http://www.interactivetools.com/forum/gforum.cgi?post=83903#83903
Using this, we can change our foreach loop to look like this:
<?php foreach (range(1,$vehiclesMetaData['totalPages']) as $page): ?>
<?php if ($page == $current_page): ?>
<span class="pagination"><strong><?php echo $page; ?></strong></span>
<span class="pagination"><strong><a href="?<?php echo http_build_query(array_merge($_REQUEST, array( 'page' => $page ))) ?>"><?php echo $page; ?></a></strong></span>
This will maintain your search options.
