Instant Web Site Favorite to Favourite
Re: [Paulc] Instant Web Site Favorite to Favourite
By Jason - August 8, 2011
It would be possible to write a custom script that would search through your sections and look for instances of the world "Favorite" and change it to "Favourite", however, if you don't have a lot of records, it would probably be easier to do this by hand. As far as the page templates, you'd have to search through them manually one at a time.
If you'd like us to create a custom script for you, you can email consulting@interactivetools.com and we can go over your options.
Re: [Jason] Instant Web Site Favorite to Favourite
By (Deleted User) - August 9, 2011
Hi Jason it is only a small site so will replace each instance thanks for your reply
