Empty Date displays default date
21 posts by 5 authors in: Forums > CMS Builder
Last Post: August 24, 2011   (RSS)
By trebien - August 15, 2011
Setting up an "events" page... leaving the date field empty in the editor, but the PHP output shows a date in 1999 instead of nothing. Some event have no date associated with them, so if it's blank, I want the field to remain blank...
Any thoughts?
Re: [trebien] Empty Date displays default date
By Steve99 - August 16, 2011
Go to Admin -> Section Editors, and click modify on your "events" editor. Then click modify for your date field. In the Field Options area, change the default value to "None/Blank" and that should do the trick!
Re: [steve99] Empty Date displays default date
By trebien - August 17, 2011
That's the thing... that's how we have it set!
We also tried changing that option, saving... then changing it back... but same thing... weird.
By Steve99 - August 17, 2011
Okay. As a fix, you can add a checkbox field to your section editor to toggle "Yes / No" and wrap your date code output in an "IF" statement.
Example:
New Field = display_date (checkbox in your section editor)
Inside your "foreach" loop around your date output:
<?php if ($record['display_date'] == 'Yes'): ?>
<?php echo $record['date'] ?>
By robin - August 17, 2011
Hey,
Are you directly outputting the date field? Like
Or are you running it through any functions first?
Robin
Robin
Programmer
Re: [robin] Empty Date displays default date
Just the code generated by the Code Generator:
<?php echo date("D, M jS, Y g:i a", strtotime($record['date'])) ?>
Is the wrong date that it's outputting November 30th, 1999?
Robin
Programmer
Yeah, some default date.
Try the removeExtraWhitespace plugin that Dave Edis created (attached).
It automatically checks for fields that only contain blank spaces as well as blank dates.
The plugin requires 2.05
That should get you going,
