categories and sub-categories question
8 posts by 2 authors in: Forums > CMS Builder
Last Post: October 4, 2011   (RSS)
Re: [furcat] categories and sub-categories question
By Jason - September 29, 2011
Are your contractors stored in a section different from your categories? So when you select a category/subcategory, you want to see all the contractors where on of those has been selected. Is that right?
Could you attach your current code so I could take a look at what you have so far? Also, if you could give me more information about how your sections are set up, we should be able to figure something out.
Re: [Jason] categories and sub-categories question
By furcat - October 1, 2011
Yes, basically. My contractors are separate from the parent and sub categories. My customer has just been selecting sub-categories off of the list I have set up, and I would like to have any contractor in a sub-category show up if the parent category is selected from the menu, without having to explicitly select the parent. Is this possible without going back into the data and selecting the parent category for each one?
Is it possible to have you take a look at the code without posting it where it can be viewed on the forum?
Thank you.
By Jason - October 3, 2011
Take a look at this post:
http://www.interactivetools.com/forum/gforum.cgi?post=90272#90272
Does this sound like what you want to accomplish?
Hope this helps get you started.
By furcat - October 3, 2011
Well, that's sort of what I want to do. But, looking at someone else's code isn't doing it for me. So, is the only way to get an answer is to post code in the forum? Is there a way to send it via email? Do I have to buy support to get an answer?
I went in my customer's data and hand selected the parent category for each record. Cumbersome and inelegant, but, at least I can display all records for a parent category.
However, how do you get the NAME of the parent? I can get the number, but not the name.
Thanks.
By Jason - October 4, 2011
If your using a drop down list, you could use the :label pseudo field.
For example:
<?php echo $record['category:label'];?>
By furcat - October 4, 2011
That worked. Thank you!
