password reminder not working after cms upgrade
By 4cdg - September 8, 2011
I had password reminder page setup and working at this link www.stoddardmls.com/pw_remind.php I copied the code directly from user-password-request.php in membership module.
I had to upgrade my cms to 2.12 and now when I submit password reminder it gives me this error message.
Notice: Undefined variable: errors in /usr/local/www/stoddardmls.com/pw_remind.php on line 51 Mail Error:
Re: [4cdg] password reminder not working after cms upgrade
By robin - September 8, 2011
Hey,
Does it still send the reminder even with the error? Could you post the part of the code that is generating the error and we'll take a look?
Robin
Robin
Programmer
Re: [robin] password reminder not working after cms upgrade
i does still send the email.
I am not sure what part of code is causing error, it says line 51 in error message, I haven't changed anything from the example that comes with the plugin. I attached the document to the last message, here is what lines 38 to 52 look like
$emailTemplate = "emails/user-password-request.php";
$emailHeaders = emailTemplate_load(array(
'template' => websiteLogin_pluginDir() . "/$emailTemplate",
'subject' => '', // set in template
'from' => '', // set in template
'to' => $user['email'],
'placeholders' => array(
'username' => $user['username'],
'loginUrl' => "http://" . $_SERVER['HTTP_HOST'] . $GLOBALS['WEBSITE_LOGIN_LOGIN_FORM_URL'],
'resetUrl' => "http://" . $_SERVER['HTTP_HOST'] . $GLOBALS['WEBSITE_LOGIN_RESET_URL'] . $resetQuery,
$mailErrors = sendMessage($emailHeaders);
if ($mailErrors) { die("Mail Error: $errors"); }
By Jason - September 9, 2011
It looks like the wrong variable is being used on that last line, try changing this:
to this
if ($mailErrors) { die("Mail Error: $mailErrors"); }
Re: [Jason] password reminder not working after cms upgrade
By 4cdg - September 9, 2011
made that change, now i get this error when i submit the request
Mail Error: Undefined index: disabled
By robin - September 9, 2011
Hey,
Looks like you're running into this problem now:
http://www.interactivetools.com/forum/gforum.cgi?post=89903;#89903
Hope that helps,
Robin
Robin
Programmer
that fixed it.
thanks guys
