How to make a back link to list page the same which came?
16 posts by 7 authors in: Forums > CMS Builder
Last Post: December 10, 2011   (RSS)
By jarvis - May 24, 2010
That code will work just fine for that
By Donna - May 24, 2010
Hi pod9,
Yes, "wydarzenia-lista.php" was specific to Esteban. For your own page, simply replace that with your own list page filename. :)
Donna
Re: [Chris] How to make a back link to list page the same which came?
By Mikey - December 8, 2011
Exactly what I needed! Thanks Chris!!!!!
Zick
Re: [zick] How to make a back link to list page the same which came?
By ross - December 9, 2011
Hi Zick
I can add it to the list. Not sure when or how that will be implemented, but it's on the list!
Ross Fairbairn - Consulting
By Mikey - December 10, 2011
Hi esteban,
Sorry, my fault. I had an extra "> in the code. I've edited my post above to remove it. Please remove the code in red below from your wydarzenia-lista.php page:
<a href="wydarzenia-art.php?page=<?php echo @$_REQUEST['page'] ? htmlspecialchars($_REQUEST['page']) : 1 ?>">&num=<?php echo $record['num'] ?>">
What is this record variable in my case?
It must be already correct since the code is working.
Please let me know if you have any questions.
Hey Chris,
I ran this through W3C validation and it was producing errors, so I made a slight change and it passed validation. Below in red is the change I made:
<a href="wydarzenia-art.php?page=<?php echo @$_REQUEST['page'] ? htmlspecialchars($_REQUEST['page']) : 1 ?>&amp;num=<?php echo $record['num'] ?>">
