Personalised Editor Screens
18 posts by 5 authors in: Forums > CMS Builder
Last Post: June 4, 2012   (RSS)
By Perchpole - March 8, 2012
Hi, Dave -
That sounds perfect.
I'm not exactly sure about which fields yet - as I'm just trying to find out if my suggestion is feasable - but I would be using the Membership plugin.
:0)
Perch
Re: [Perchpole] Personalised Editor Screens
By Dave - March 8, 2012
Hi Perch,
I've attached a sample custom "Add Record" form. Creating front-end edit forms takes some extra work. Here's some additional steps for what you need to do:
- install "Website Membership"
- create a record list page
- require users to login to see the page with <?php if (!$CURRENT_USER) { websiteLogin_redirectToLogin(); } ?>
- filter list to show only record users own with: 'where' => mysql_where(array('createdByUserNum' => $CURRENT_USER['num'])),
- link each record to an edit page passing the num, eg: record-edit.php?num=$num
- use the add page as a template for the edit page
- only load records if the user owns them with 'where' => mysql_where(array('createdByUserNum' => $CURRENT_USER['num'], 'num' => $_REQUEST['num'])),
- on save, use update, not insert to modify existing record.
addform_012.php 3K
By Perchpole - March 20, 2012
Hi, Dave -
This is brilliant. Just what I was hoping for. There are just two questions:
1) How do we add an "Upload" button?
2) Would it be possible to add the code of the addForm page to the bottom of an exisiting List page? In effect, could the user add a record to the page they are looking at?
(NB: I am trying to create a demo for a group of seniors and would like them to be able to see how easy it is to update their own pages. Ficking back and forth between pages will seem too complex for them. This has to be real Janet & John stuff!)
:0)
Perch
Re: [Tom P] Personalised Editor Screens
Hi, Tom -
This is an amazing bit of work! Thanks.
Unfortunately I'm receiveing an error and I don't know why?
Upload Error: <form> tag must have enctype="multipart/form-data"
Can you help?
Perch
By (Deleted User) - March 21, 2012
Hi Perch,
That error message means that the form wasn't submitted with the correct encoding type (it's an error check to make sure that the uploads won't be encoded and corrupted).
To make sure that the form works properly, check that the following line exists (it was line 79 in my uploadForm script):
<form method="post" name="uploadForm" action="?preSaveTempId=<?php echo $preSaveTempId ?>" enctype="multipart/form-data">
Let me know if this helps,
Tom
By gkornbluth - June 1, 2012
Is there a way to include info fields in the upload dialog so that info1-5 can be populated by entries in the upload form?
Re: [gkornbluth] Personalised Editor Screens
By Jason - June 4, 2012
Do you mean having the info fields be drop downs that are populated by other parts of the database? If so, this is possible, but would require a fair amount of customization. Please email consulting@interactivetools.com if you would like to go over some options.
