Rebuild CMS Schema
Last Post: August 7, 2012 (RSS)
By alissibronte - August 6, 2012 - edited: August 6, 2012
Hi guys,
I tried to find a "News" section schema file but I can't found it.
However, I find that there are deleted sections schema files.
Is there any way to rebuild all the schema files in order to have a data / schema clean?
Thank you in advance!
Re: [alissibronte] Rebuild CMS Schema
By Jason - August 6, 2012
Schema files should be deleted when you remove a section. Do you have a news section in the CMS, but you can't find the schema file for it? Is there a reason you need to edit the data/schema folder?
Let me know.
Let me know.
Re: [Jason] Rebuild CMS Schema
Sorry Jason,
was working in the wrong directory. Everything is correct.
Regards!
Regards!
By Jason - August 7, 2012
No problem. Glad to hear everything got sorted out.
Please let me know if you have any other questions.
