Category subnav changing based on url
11 posts by 3 authors in: Forums > CMS Builder
Last Post: November 29, 2012   (RSS)
I have had trouble with this twice now, the first time I was able to manually remedy the issue, but I cannot this time.
I have a subnav created with the category function, that is all working fine. The issues is when I click a link to go to my detail page, the subnav changes based on the record number in the url (image attached). As you can see the "Online Exhibitions" second level links are active, they should not be. The active page should be "Online Collections" but because the url is pulling record 10 the navigation believes one of the other items are selected.
Hope this all makes sense, if needed I can provide code.
Re: [clowden] Category subnav changing based on url
Hi clowden,
It's always helpful when you provide the code.
Could you attach your list and detail viewers to a post?
Hi Clowden,
I've had a look at your code, but I can't see where your using the $subNav variable. I guess it's in the footer or subnav.inc.php files? Would it be possible to attach these as well?
Re: [greg] Category subnav changing based on url
Sorry about that Greg, didn't think about including that. File uploaded.
subnav-inc.php 1K
Hi Clowden,
I've done some local testing and looked at your code, I think something like this should work:
<?php header('Content-type: text/html; charset=utf-8'); ?>
// load viewer library
$libraryPath = 'admin/lib/viewer_functions.php';
$dirsToCheck = array('/home7/mizrahio/public_html/hunt_dev/','','../','../../','../../../');
// load page content
list($page, $pageMetaData) = getRecords(array(
'tableName' => 'online_collections',
'where' => whereRecordNumberInUrl(1),
$page = @$page[0]; // get first record
list($navData, $navMetaData) = getRecords(array(
'tableName' => 'archives',
'limit' => '1'
$navData = @$navData[0]; // get first record
//find the top level navigation num value
$selectedCat = explode(':', $navData['lineage']);
$selectedCat = $selectedCat[1];
list($subnav, $subnavCategory) = getCategories(array(
'defaultCategory' => 'first',
'selectedCategoryNum' => $selectedCat,
'categoryFormat' => 'onelevel',
So the green getRecord statement finds the currently selected menu item, and then finds the top level entry it's linked too from the lineage field and stores it against the $selectedCat variable.
In the getCategories function I've added the selectedCategoryNum key, which lets the getCategories function know which is the current parent category.
Let me know if you have any problems.
Thank you very much for your help.
I added the code to my detail.php page and got nothing. Didn't get an error either. Any ideas?
Hi Clowden,
Is it returning an error or an empty array at all? Did you paste this code over the code that is currently at the top of your page?
It is not returning anything at all (errors or empty array), its doing the exact same thing it was before. I pasted it over what I had yes.
Could you fill out a second level support request and I can take a closer look at how you have your sections set up? You will need to fill out this form:
