Dynamically populate a drop down menu from one of my fields and remove duplicates
Last Post: December 27, 2012   (RSS)
By gkornbluth - December 21, 2012 - edited: December 21, 2012
I’m stumped again...
Back in 2009, there was a now archived post #70187 that asked the same question “How do I dynamically populate a drop down menu from one of my fields (and remove duplicates from the drop down)”
It suggested using the following
<?php foreach ($categoryRecords as $record):
$productCategory[] = $record['category'];
endforeach;
<?php $productCategory = array_unique($productCategory); ?>
<select name="category_match">
<?php foreach ($productCategory as $record): ?>
<option value="<?php echo htmlspecialchars($record) ?>"><?php echo htmlspecialchars($record) ?></option>
</select>
In my implementation, I’m using the record number for option values and the pseudo :label field for label values.
When I use the code below, I get this error when a search is executed:
Notice: Undefined variable: mobilityAidCategory in /hsphere/local/home/gkornblu/jkwebdesigns.com/drlaura7.php on line 113 Warning: array_unique(): The argument should be an array in /hsphere/local/home/gkornblu/jkwebdesigns.com/drlaura7.php on line 113
<?php foreach ($mobility_aidsRecords as $record):
$mobilityAidCategory[] = $record['mobility_aid_category:label'];
endforeach;
<?php $mobilityAidCategory = array_unique($mobilityAidCategory); ?>
<select name="mobility_aid_category_match">
<?php foreach ($mobilityAidCategory as $record): ?>
<option value="<?php echo htmlspecialchars($record) ?>"><?php echo ($record) ?></option>
</select>
Any ideas?
Are these labels coming from a list field? If they are then this might be an easier way of doing it:
 <select name="profession" class="textbox" id="profession">
   <option value= "">Select Publication Type</option>
   <?php foreach(getListOptions('table_name_here', 'mobility_aid_category') as $value => $name): ?>
      <option value="<?php echo $value; ?>"><?php echo $name; ?></option>
</select>
If you replace table_name_here with the table name that contains the list field you want to use.
getListOptions is a CMS Builder function that should automatically generate an array of drop down options for you.
</select>
By gkornbluth - December 22, 2012 - edited: December 22, 2012
Thanks for this. It certainly simplified the code required.
I've modified the code you suggested to eliminate those categories that do not have records associated with them, but can't seem to get rid of the duplicate entries in the list when there is more than one record in that category.
IE If there are 3 record in one of the categories that category will appear in the pull doen options list three times.
Here's the code that I'm using:
 <select name="mobility_aid_category" >
   <option value= "">Choose The Category To Display And Click/Tap The Search Button</option>
   <?php foreach(getListOptions('mobility_aids', 'mobility_aid_category') as $value => $name): ?>
   <?php foreach ($mobility_aidsRecords as $record): ?>
   <?php $in_list = $record['mobility_aid_category:label'] ?>
    <?php if ($name == $in_list ):?>
      <?php endif  ?>
   <?php endforeach; ?><?php endforeach; ?>
</select>
If your already pulling all of the relevant records for the section and you only want to show items in the drop down that have been already selected, it might be easier to do something like this:
//Create an array to store the values that have been selected
$selectArray = array();
//foreach section item
foreach($mobility_aidsRecords as $record){
  //If the record has something selected for mobility_aid_category
  if(@$record['mobility_aid_category:label']){
    //If the selected value isn't already in the array
    if(!in_array(@$record['mobility_aid_category:label'],$selectArray)){
      //Add it to the $selectArray
      $selectArray[$record['mobility_aid_category']] = $record['mobility_aid_category:label'];
  <?php foreach ($selectArray as $value => $name): ?>
</select>
Let me know if this doesn't work.
