How to add search feature on my site.
23 posts by 6 authors in: Forums > CMS Builder
Last Post: January 2, 2013   (RSS)
Hi Greg
There are 3 STEPs on your search code.
I need to searh whole site information.   Do I need to post all 3 steps code on each page?
It seems a long code for search feature.
Is there any simple code that for search feature for a whole site?
-Jax H.
Hi JH,
Take a look at Google site search. It might help.
There's a free (advertising) and a paid version (no ads)
http://www.google.com/cse/
There are also a number of stand alone PHP based search scripts that you can use, some free, some not free. Do a Google search for "PHP site search scripts".
Hope that helps
Hi Jerry
I hope I can build a site search with cmsBuilder.
Thanks a lot!
Jac
-Jax H.
Hi JH,
Which three steps are you referring too? Is it these three:
http://www.interactivetools.com/forum/forum-posts.php?postNum=2218303#post2218303
That code only needs to appear on the page that displays the search results. If you want to add a search box to any other page that links to your search results page, you could add this form:
<form method="POST" action="nameOfResultsPage.php">
<input type="text" name="q" value="<?php echo @$_REQUEST['q']; ?>">
<input type="submit" name="submit" value="Search">
</form>
You will need to change the name of nameOfResultsPage.php to the name of your search results page.
Hi Gerg
Happy new year!   Thanks so much for your reply!
Yes. I followed your code and changed the URL : nameOfResultsPage.php.
In the searchResult.php page.     Only the "Title" field is correct.
I would like to display images, title, brief, intro on my searchResults.php page.
Above all are my products section fileds.
They are all incorrect.
Most of important.  when clieck the result item.  got wrong page.
I tried to study "http://www.interactivetools.com/forum/forum-posts.php?Search-Field-72696&page=2"
Here is my code:
// load viewer library
$libraryPath = 'cmsAdmin/lib/viewer_functions.php';
$dirsToCheck = array('/home/quanmax/public_html/','','../','../../','../../../');
$searchOptions = array();
$searchOptions['keywords'] = @$_REQUEST['q'];
$searchOptions['perPage'] = "10";
$searchOptions['debugSql'] = "0";
$searchTables = array();
$searchTables['products'] = array(
'viewerUrl' => 'products-detail.php',
'titleField' => 'title',
'summaryField' => 'brief',
'searchFields' => array('title','brief','intro'),
list($searchResults, $searchMeta) = searchMultipleTables($searchTables, $searchOptions);
if(!$searchResults){
$error = "I'm sorry, no results have been found. Please try a different search term.";
list($productsRecords, $productsMetaData) = getRecords(array(
'tableName' => 'products',
'where' => whereRecordNumberInUrl(1),
'orderBy' => mysql_escape(@$_REQUEST['orderBy']),
'limit' => '10',
$productsRecord = @$productsRecords[0]; // get first record
Form code
<form method="post" action="searchResults.php">
<input type="text" name="q" value="<?php echo @$_REQUEST['q']; ?>" size="15" />
<input class="btn" type="submit" name="submit" value="Search" />
</form>
Result code
<?php if ($searchMeta['invalidPageNum']): ?>
Results page '<?php echo $searchMeta['page']?>' not found, <a href="<?php echo $searchMeta['firstPageLink'] ?>">start over &gt;&gt;</a>.<br/>
<?php elseif ($searchOptions['keywords'] && $searchMeta['noRecordsFound']): ?>
No records matched search query!<br/>
<br/>
<?php elseif ($searchOptions['keywords'] == ""): ?>
Enter a keyword to search.<br/>
<br/>
<?php foreach ($searchResults as $record): ?>
<a href="<?php echo $record['_link'] ?>"> <?php echo $record['_title'] ?> </a> Record Number: <?php echo $record['num'] ?>
<br />
<br />
<?php foreach ($productsRecord['images'] as $index => $upload): ?>
<?php if ($upload['isImage']): ?>
<img src="<?php echo $upload['thumbUrlPath'] ?>" alt="" width="150" height="150" border="0" />
<br />
<br />
<?php if ($record['_summary']): ?>
<?php echo $record['_summary'] ?><br/>
No description available for page.<br/>
<br/>
<?php if ($searchMeta['prevPage']): ?>
<a href="<?php echo $searchMeta['prevPageLink'] ?>">&lt;&lt; prev</a>
&lt;&lt; prev
- page <?php echo $searchMeta['page'] ?> of <?php echo $searchMeta['totalPages'] ?> -
<?php if ($searchMeta['nextPage']): ?>
<a href="<?php echo $searchMeta['nextPageLink'] ?>">next &gt;&gt;</a>
next &gt;&gt;
Here is my page : http://174.132.79.189/~quanmax/en/searchResults.php
Hope you can help.
Thank you a lot!
Jac
-Jax H.
By gregThomas - December 27, 2012 - edited: December 27, 2012
Hi Jac,
Looking at your current code your only searching the products section, do you want to search other sections as well? Just wanted to check before I suggest anything.
Hi Gerg
yes only product section need to search.not whole site.
Thanks a lot!
jac
-Jax H.
Hi Gerg
Thank you a lot for your reply.
Yes. The code is quite simple.
but I still can not display image and link correctly.
Here is my code:
Head
'perPage' => '10',
'loadUploads' => true,
'allowSearch' => true,
Search field :
<form method="POST" action="search.php">
<input type="text" name="title_keyword" value="">
</form>
Search Result php page:
<?php foreach ($productsRecords as $record): ?>
Record Number: <?php echo htmlencode($record['num']) ?><br/>
Title: <?php echo htmlencode($record['title']) ?><br/>
intro: <?php echo $record['intro']; ?><br/>
<!--Try product image code 1-->
<img src="<?php echo $upload['thumbUrlPath'] ?>" alt="<?php echo htmlencode($productsRecord['title']) ?>" width="<?php echo $upload['thumbWidth'] ?>" height="<?php echo $upload['thumbHeight'] ?>" hspace="20" /><br/>
<!--Try product image code 1 end-->
<!--Try product image code 2-->
<img src="<?php echo $upload['urlPath'] ?>" width="<?php echo $upload['width'] ?>" height="<?php echo $upload['height'] ?>" alt="" />
<img src="<?php echo $upload['thumbUrlPath'] ?>" width="<?php echo $upload['thumbWidth'] ?>" height="<?php echo $upload['thumbHeight'] ?>" alt="" />
<img src="<?php echo $upload['thumbUrlPath2'] ?>" width="<?php echo $upload['thumbWidth2'] ?>" height="<?php echo $upload['thumbHeight2'] ?>" alt="" /> <br/>
_link : <a href="<?php echo $productsRecord['_link'] ?>"><?php echo $productsRecord['_link'] ?></a><br/>
I tried 2 different image code.  I generated product page code using the CMS Builder code generator.
It seems simple way to do it.
but Image and Link code still in error.
Here is my page for testing:
http://174.132.79.189/~quanmax/en/search.php
Yes I have study CmsAdmin search guide.   but dont' know how to use it.
http://www.interactivetools.com/docs/cmsbuilder/viewer_search.html
My face got blue.
Please kindly help.
Jac
-Jax H.
Hi Jac,
I think the problem is this line:
<?php foreach ($record['images'] as $index => $upload): ?>
The images are stored under each record in the section as opposed to in the section array, so the variable you need is $record and not $productRecord
If this doesn't work, could you attach your search.php file to a post so I can see which lines are causing problems?
