CRON Error
Last Post: May 6, 2013 (RSS)
Hi Guys
I just upgraded to CMSB 2.53 and got the following cron error:
Warning: require_once(/home/acl/public_html/newfoundland/builder/lib/old_alias_functions.php): failed to open stream: No such file or directory in /home/acl/public_html/newfoundland/builder/lib/init.php on line 30
Fatal error: require_once(): Failed opening required '/home/acl/public_html/newfoundland/builder/lib/old_alias_functions.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/acl/public_html/newfoundland/builder/lib/init.php on line 30
Any ideas??
northernpenguin
Northern Penguin Technologies
"Any sufficiently advanced technology
is indistinguishable from magic."
........Arthur C. Clarke
By gregThomas - May 1, 2013
It looks as if CMS Builder is looking in the correct directory for the old_alias_functions.php file, does that file exist in home/acl/public_html/newfoundland/builder/lib?
I would try carrying out the upgrade process again as it sounds like something might have not got overwritten or corrupted. If that doesn't work, could you fill out a second level support request? You can find the form here:
The file exists. I will complete a second level support request.
northernpenguin
By northernpenguin - May 1, 2013 - edited: May 1, 2013
Greg: Sorry, I sent you the wrong Support Ticket information - SVD-636077 (actually the logins are correct, the details of the problem should read CRON, not Spambot Email Protector)
northernpenguin
By Jason - May 6, 2013
Just wanted to check in and make sure this issue was resolved. Please let me know if you have any other questions.
Yes, it looks like it as it has not reappeared.
northernpenguin
