CMSB 2.14 not recognising values in list
Last Post: September 3, 2013   (RSS)
Hello InteractiveTools,
I have created a multi value list in order to create country categories. When I try to create category pages CMSB is not recognising the query. I also ran the query directly in MySQL and it too does not recognise it. I then used a textfield to manually type in the country, CMSB recognised this.
How do I get the multi value list to work?
Terry
In summary:
FOLLOWING DOES NOT WORK. "country" is a multi value list
CMSB:
  // load records
  list($testRecords, $testMetaData) = getRecords(array(
    'tableName'   => 'test',
    'where' => 'country = "Kenya"',
MYSQL:
   SELECT *
   FROM `cms_test`
   WHERE `country` = 'Kenya'
   LIMIT 0 , 30
THE FOLLOWING WORKS! "country_tag" is a textfield
CMSB:
  // load records
    'where' => 'country_tag="Kenya"',
MYSQL:
   SELECT *
   FROM `cms_test`
   WHERE `country_tag` = 'Kenya'
   LIMIT 0 , 30
Hi Terry,
The values for a multi value list field are stored in a tab separated string, so to search them you'd need to use something like this:
  // load records
    'where' => "`country` LIKE '%\tKenya\t%'",
So the getRecords where string will return records where the country field has a string which contains that contains the value Kenya with a tab value before and after it. The same select statement would look like this:
   SELECT *
   FROM `cms_test`
   WHERE `country` LIKE '%  Kenya  %'
   LIMIT 0 , 30
Good to hear from you.
The tab separated string works in CMSB but doesn't run in MySQL (as a direct SQL query) but don't worry about that, I am not hand-writing code.
Can I ask one more question?
I want to build a category list page - quite similar to the viewer List Page. So for example, I will run country tags at the end of each story (see code) and hyperlink each to a list page. I would have to numerous individual pages with the getRecord string you provided in order to achieve this. Is there a way that I can create a single template to do this in the same way that the viewer List Page and Detail Page are built?
  $country = array_combine($record['country:values'], $record['country:labels']);
  $countryCount = count($country);
  $i = 1;
  foreach($country as $value => $label): ?>
  <a href="<?php echo strtolower($label);?>.php" title="Headlines of all <?php echo $label; ?> stories"><?php echo $label; ?></a> <?php if($i != $countryCount){ echo ','; } ?>
  <?php $i++; ?>
<?php endforeach; ?>
Hi Terry,
Glad you've got it working. Let me know if you have any questions.
