extracting an email address from a text field
11 posts by 2 authors in: Forums > CMS Builder
Last Post: November 27, 2013   (RSS)
I’ve got a text field ( internal_notes ) in my user accounts table which contains an email address (always surrounded by spaces), and I want to capture that email address and ultimately insert it into the email address field in the same record.
I found the following function at: http://stackoverflow.com/questions/1028553/how-to-get-email-address-from-a-long-string
I’m sure it’s something really silly, but don’t seem to be able to get it working.
Any ideas?
function extract_email_address ($string) {
   $emails = array();
   $string = str_replace("\r\n",' ',$string);
   $string = str_replace("\n",' ',$string);
   foreach(preg_split('/ /', $string) as $token) {
        $email = filter_var($token, FILTER_VALIDATE_EMAIL);
        if ($email !== false) {
            $emails[] = $email;
    return $emails;
<?php foreach ($accountsRecords as $record): ?>
<?php echo extract_email_address ($record['internal_notes']) ?>
By Dave - November 18, 2013
Can you provide some example content that it's not working for?
Here's a working example:
   $emails = array();
            $emails[] = $email;
    return $emails;
$string = "Hello there this
is a user@example.com test of emails
in a string@example.com";
$emails = extract_email_address($string);
print "Emails found: ";
print_r($emails);
exit;
Outputs: Emails found: Array ( [0] => user@example.com [1] => string@example.com )
Let me know, thanks!
Thanks again,
I'll try it out
I’ve managed to isolate all the email addresses from the internal_notes text field in each user's record using this function:
function extract_emails_from($string){
    preg_match_all("/[\._a-zA-Z0-9-]+@[\._a-zA-Z0-9-]+/i", $string, $matches);
    return $matches[0];
<?php $text =  htmlencode($record['internal_notes']) ?>
<?php $emails = extract_emails_from($text);?>
The Email Alone: <?php foreach($emails as $email) {
    echo $email ;
My next challenge is to insert the email addresses into the currently blank email field in that user’s record. (without breaking anything...)
Any suggestions?
Thanks for this Dave,
Looks pretty scary, so I think I'll try it on a test install first.
I'll let you know how it goes
By Dave - November 21, 2013
Sure thing.  Here's some more self-documenting code so you can see how it works:
// uncomment this line once you've confirmed emails look as desired
$tableName    = 'accounts';
$recordNum    = $record['num']
$where        = '';
$colsToValues = array();
$colsToValues['your-email-field'] = $emailsAsCSV;
mysql_update($tableName, $recordNum, $where, $colsToValues);
So basically what it does is update records in 'accounts' that match the recordNumber and/or where statements, updating ONLY the fieldnames/columns listed in $colsToValues.  If you wanted to do a test run you could create a field called 'test' and update that with $colsToValues['test'] instead of the other fieldname (whatever that other fieldname may be that you want to update).
I added the if statement below to leave any existing emails alone, but came up with one interesting issue.
Some of the records have more than one email address in the internal_notes field.
How can I limit the capture to only the first one?
Thanks as always,
  foreach ($accountsRecords as $record) {
    $text   = htmlencode($record['internal_notes']);
   if ($record['email']) { $emails[] = $record['email']; } // add any pre-existing email content
    $emailsAsCSV = implode(',', $emails);
    print "User {$record['fullname']} has these emails: $emailsAsCSV<br/>\n";
 if (!$record['email']) { mysql_update('accounts', $record['num'], null, array('email' => $emailsAsCSV));}
By Dave - November 22, 2013
If you only want the first captured emails, and don't need to worry about what was already in the field you are updating, then you could use this (untested) code:
    if ($record['email']) { continue; } // skip records that already have an email set
    $allEmails  = extract_emails_from( $record['internal_notes'] );
    $firstEmail = @$allEmails[0];
    print "User {$record['fullname']} will get this email: $firstEmail<br/>\n";
    mysql_update('accounts', $record['num'], null, array('email' => $firstEmail ));}
I removed htmlencode(), if you need that for some reason just add it back in.
Let me know how it goes!
By gkornbluth - November 22, 2013 - edited: November 22, 2013
WOW! It's  good... And Elegant!
Worked just as you expected (although I had my arms, fingers, legs and toes crossed when I fired it up)
This is definitely one for the Cookbook!
