Checking Links to Records in a Detail Page
Last Post: April 1, 2014   (RSS)
By Mohaukla - March 25, 2014
I have added a prev next record link in a details page but there must be something with table because I get this error:
Notice: Undefined variable: blogRecord in C:\Webspace\resadmin\mmoyers\justritedesign.com\www\jrd7\single_post.php on line 22 MySQL Error: Unknown column 'date' in 'order clause' PHP Notice: Undefined variable: blogRecord in C:\Webspace\resadmin\mmoyers\justritedesign.com\www\jrd7\single_post.php on line 22
    list($blogRecords, $blogMetaData) = getRecords(array(
    'tableName'   => 'blog',
    'where'       => whereRecordNumberInUrl(0),
    'loadUploads' => true,
    'allowSearch' => false,
    'limit'       => '1',
    list($prevRecord, $nextRecord, $firstRecord, $lastRecord) = getPrevAndNextRecords(array(
    'recordNum' => $blogRecord['num'],
    'orderBy'   => 'date DESC'
    $blogRecord = @$blogRecords[0]; // get first record
    if (!$blogRecord) { dieWith404("Record not found!"); } // show error message if no record found
                           <?php if (@$prevRecord['num']): ?>
                           <a href="<?php echo (@$prevRecord['_link'])? $prevRecord['_link'] : '?' ; ?>"><i class="fa fa-angle-double-left"></i> <?php echo (@$prevRecord['_title'])? $prevRecord['_title'] : '?' ; ?></a>
                           <?php else: ?>XXXXXX<?php endif ?>
                           <?php if (@$nextRecord['num']): ?>
                           <a href="<?php echo (@$nextRecord['_link'])? $nextRecord['_link'] : '?' ; ?>"><?php echo (@$nextRecord['_title'])? $nextRecord['_title'] : '?' ; ?> <i class="fa fa-angle-double-right"></i></a>
                           <?php else: ?>++++++<?php endif ?>
I am hoping that I can also swap "_link" for "_title" so that it will put the title of the the prev and next posts are. You may have to correct me there if I'm incorrect about that.
Not sure about the date column being a problem.
Thanks for any help you can give
Michael Moyers
Michael Moyers
Owner of Just Rite Design Inc. A growing network of professionals in web design, graphic design, flash development, programming, and audio & video productions.
"Due to budget constraints, the Light at the end of the tunnel will be temporarily out!"
By Mohaukla - March 31, 2014
OK almost there.
The link to the next post works but only on the first post. So post 1 has XXXX (meaning  no previous post) and the proper title and link to the next post. Now when you click on the link for the next post the correct post shows but now both links at the bottom point back to the original post.
So I have 4 posts
Post 1 has
XXXX - Title/Link to Post 2
Post 2 has
Title/Link to Post1 - Title/Link to Post 1
Post 3 has
Title/Link to Post 2 - Title/Link to Post 1
Post 4 has
Title/Link to Post 3 - Title/Link to Post 1
It is not getting the NEXT link except the first post.
Let me know what you think.
Michael
Michael Moyers
By Chris - March 31, 2014
Hi Michael,
That's very peculiar. I've been doing a bunch of tests here to try to figure this out, but I've run out of ideas. Can you provide me with your FTP information with a Second Level Support Request so I can take a closer look?
https://www.interactivetools.com/support/email_support_form.php?message=http://www.interactivetools.com/forum/forum-posts.php?Checking-Links-to-Records-in-a-Detail-Page-79391&page=1
If not, can you please add 'debugSql' => true to both your getRecords() and getPrevAndNextRecords() and paste the results here?
  'limit'       => '1',
  'debugSql'    => true,
  'orderBy'   => 'date DESC',
  'debugSql'  => true,
Can you also post your Mysql version? You'll find this at the bottom of the Admin > General Settings page. For example, mine is:
Database Server: MySQL v5.0.37 (Max Connections: 255)
By Mohaukla - March 31, 2014 - edited: March 31, 2014
I will send a request as well but here is the other info you asked for:
SELECT SQL_CALC_FOUND_ROWS `blog`.*
FROM `cms_blog` as `blog`
 WHERE (num = '3')
 ORDER BY  post_date
 LIMIT 1tableName = 'blog' AND
fieldName IN ('main_image') AND
recordNum IN (3)
 ORDER BY `order`, numSELECT SQL_CALC_FOUND_ROWS `accounts`.*
FROM `cms_accounts` as `accounts`
 WHERE (`num` IN (1))
 ORDER BY fullname, usernameSELECT @lastSeenNum:=0, @prevNum:=0, @nextNum:=0, @firstNum:=0, @lastNum:=0, @prevNumSet:=0, @foundTarget:=0SELECT
  IF(@firstNum, NULL, @firstNum:=num),
  @lastNum := num,
  IF(num='3', (@foundTarget:=1) AND (@prevNum:=@lastSeenNum), @lastSeenNum:=num),
  IF(@foundTarget=1 AND num !='3' AND @nextNum = 0, @nextNum := num, null)
FROM `cms_blog`
ORDER BY  post_date
SELECT @prevNum as 'prevRecordNum', @nextNum as 'nextRecordNum', @firstNum as 'firstRecordNum', @lastNum as 'lastRecordNum'SELECT SQL_CALC_FOUND_ROWS `blog`.*
 WHERE (num IN (2,1,1,4,0))
 ORDER BY  post_datetableName = 'blog' AND
recordNum IN (1,2,4)
MySQL v5.5.33 (Max Connections: 25)
Michael Moyers
By Chris - April 1, 2014
Hi Michael,
I'm still mystified. Have you sent in your details? I can't see them in our ticket queue.
By Mohaukla - April 1, 2014
Yes check FAB-339040
Damon replied to me because it had some info on a license swap.
Michael
Michael Moyers
Thanks, Michael!
I did some tests on your server and was able to track down a mysterious bug (I think in MySQL) which seems to affect a small number of servers. I've patched the copy of CMS Builder installed on your site and getPrevAndNextRecords() is working correctly now on your single_post.php pages. Future versions of CMS Builder will contain this fix, so you'll be able to upgrade safely in the future and hopefully no one else will run into this issue! :)
Thanks Chris
As always you guys rock!
Michael Moyers
