Permalinks page works but does not load images
Last Post: July 28, 2014   (RSS)
By Steve99 - July 28, 2014
Hi Andy,
I took a look at the links and think it is probably just a javascript include issue. The comments below are assuming you are utilizing the PREFIX_URL set as "/~javeahom" within the General Settings area.
Beneath your "JS Page Level" html comment, it looks like you need to change this:
    <script src="sliderengine/jquery.js"></script>
    <script src="sliderengine/amazingslider.js"></script>
    <script src="sliderengine/initslider-1.js"></script>
To this:
    <script src="<?php echo PREFIX_URL; ?>/property/sliderengine/jquery.js"></script>
    <script src="<?php echo PREFIX_URL; ?>/property/sliderengine/amazingslider.js"></script>
    <script src="<?php echo PREFIX_URL; ?>/property/sliderengine/initslider-1.js"></script>
That should fix the issue you are experiencing.
If you are NOT using the PREFIX_URL setting, you'll have to set those up as such:
    <script src="/~javeahom/property/sliderengine/jquery.js"></script>
    <script src="/~javeahom/property/sliderengine/amazingslider.js"></script>
    <script src="/~javeahom/property/sliderengine/initslider-1.js"></script>
Let me know how it goes. Hope this helps.
Steve
By andybarn - July 28, 2014
Thanks Steve!
You are a star, I changed to
and it now works perfectly!
Thank you so much for your help.
Kind regards
Andy
You're very welcome!
Now that's working in your dev environment. When the site is being prepped to go live, just make sure to remove "/~javeahom" from those source file links so it starts with "/property" and you'll be good to go.
Cheers!
Steve
