Redirect URL
Last Post: December 16, 2014   (RSS)
I have a redirect field called : redirect : that I would like to use in my code.
How can I do this?
Example:
<?php foreach ($festival_archive_2014Records as $record): ?>
<p><a href="<?php echo $record['_link'] ?>"><?php echo htmlencode($record['name']) ?></a></p>
<?php if (!$festival_archive_2014Records): ?>
No records were found!<br/><br/>
By drewh01 - December 16, 2014 - edited: December 16, 2014
I would like to insert code to the above that when the 'redirect' field in the admin is filled in with a custom URL that it will override the _link value.  Hope this makes sense.
Right now when I add this code, it duplicates any custom URL redirects that I have used.  I guess I am needing to use a foreach or a if then statement somehow?
<?php if($record['redirect']):?>
<p><a href="<?php echo $record['redirect'] ?>"><?php echo htmlencode($record['name']) ?></a></p>
<?php endif; ?>
By claire - December 16, 2014
No no, just a plain if-else will do it here. Try this:
<?php else : ?>
<?php endif; ?>
Claire Ryan
Ahhh...yes, that makes sense.  Thanks for the help...i'm still learning!
