Equivalent to the UpdatedDate field for individual uploads?
Last Post: March 17, 2015 (RSS)
By gkornbluth - March 12, 2015
Hi all,
I’m trying to automatically list the date and time when a specific upload was uploaded in a both list and detail viewer.
Is there an equivalent to the record level UpdatedDate field for individual uploads?
By Damon - March 12, 2015
Try this inside the upload foreachloop:
Created date and time: <?php echo $upload['createdTime']; ?>
An example of the output would be this:
Created date and time: 2015-03-12 18:07:19
You also use the showme function to see all the available variables and values in an array like this:
<?php showme($newsRecord['image']); ?>
Hope this helps!
Hi Damon,
Thanks for refreshing my failing memory.
I actually formatted the field output using the following:
<?php echo date("M jS, Y H:i T", strtotime($upload['createdTime'])) ?>
I'm really glad that you folks are around to bail us out.
By gkornbluth - March 13, 2015
Hi Damon,
Since the last question was easy, maybe this one will be also...
Is there a way to log failed login attempts?
Hopefully logging the failed username and failed password and IP address?
By Dave - March 17, 2015
There's nothing built in to do that. It's perhaps possible with a plugin or some custom code.
At some future point we'd like to add an "audit log" of specific user actions.
Generally you wouldn't want to log plaintext failed passwords though because then you'd be logging typos that revealed the user's actual password.
What are you trying to achieve specifically? Is it a client request or just curious?
