Just a little function humor.
Last Post: August 14, 2015   (RSS)
By rconring - August 7, 2015
I hope I am not breaking forum decorum but I just had to share this nugget with the CMSB community.
The other day, I found myself in need of a function to replace an array of placeholders with an array of variables.  I knew I had written that very function for use on another site some time ago but could not remember which site.  I did remember that I had named the function something like "replace_token" or "swap_token" ... I knew it had "token" in the name so I did a search of my web projects directory for *token*.
Holy Smoke! (pun intended)  Ironically, there is was in a little quickie site I did for a client last year .... cannabiscrusades.com!
If you don't get it, it's probably a good thing!  LOL
Ron Conring
Conring Automation Services
By rconring - August 12, 2015
Yep ... the killing of the orphans!
On a serious note while on the topic, I need to take this opportunity to see if there is a solution to a parent/child problem that I am currently having.
The WYSIWYG editor being a designer's nemesis, I am trying to create a tightly controlled structured situation for a client that cannot seem to grasp even the most basic design rules and creates the most hideous HTML that totally breaks a responsive design.  So, I am taking away his WYSIWYG field so he has to create a post which consists of post elements ... Banner Image, Slider, H1, H2, Paragraph, Photo Array, Document, Form, Video ... etc.  So, the data structure is basically a header record "posts" with related children "post_elements".  This all works very well and produces very clean responsive posts since I control every aspect of the rendered code on the front end.
The problem I am having is with the back end.  I cannot drag-sort the post elements from within the "posts" record where the preview button is.  I have to back out of the "posts" record and go to a filtered "post_elements" list in order to rearrange the elements' sort order.  Also, if I edit one of the related elements from within the "posts" record, it returns me to the "posts" listing rather than to the related "post_elements" list within the open post record.  I can manage it myself this way, but I am sure my client will never be able to.  There are probably some tweaks to the back end code to resolve this, but I haven't spent a lot of time playing with the editing environment so am at the "Ask Dave" point in this endeavor.  Is there something obvious that I am missing or would this require major surgery?
I attached a couple of screenshots.
Ron Conring
By Dave - August 14, 2015
Hi Ron,
Here's a couple things that might be of interest:
Customize WYSIWYG - You can edit/limit the buttons shown on the wysiwyg by editting /lib/wysiwyg.php.  You can save it as wysiwyg_custom.php.  The button list looks like this: formatselect,fontsizeselect,bold,italic,underline,|,justifyleft,justifycenter,justifyright,|,bullist,numlist,|,outdent,indent,|,sub,sup,charmap,|,removeformat,fullscreen
htmlPurify() - For plugin authors there's also a function in /lib/common.php called htmlPurify() that filters out unwanted HTML.  It's a bit more work to implement but works well.  We use it for this forum.  It uses an underlying library from: http://htmlpurifier.org/
Related Records Drag Sorting - Try setting this to '1' in your /data/settings file(s):  'allowRelatedRecordsDragSorting' => '0',  Note that sorting a subset of the records might produce unexpected results, so make sure you test it before relying on it.
Hope one of those help!
Hi Ron,
