Section Search - query on list items
Last Post: September 28, 2017   (RSS)
Hi All.
I have a field list called "type" and in the CMSB > section > searching I want to be able to find multiple types.  I've tried using Type | type | query, however as the field is a list, it give me a drop-down rather than a text field.
ie.  I want to find a reservation that is not "wedding", so I should be able to search for " - wedding"?
Or.  I need to be able to "multi-select" so I can choose multiple types (the types that are not wedding)
Any ideas?
By JeffC - September 23, 2017
Apologies for jumping in on this thread with an unrelated question.
I have a client in Australia that is looking for a reputable host provider. He currently uses crazy domains whose service, in his experience is unreliable.  Toledoh, I notice you are in Australia, can you recommend anyone.
Sorry again for jumping in. I looked but I don't think you can send a direct message to other users on this forum, and assumed you would probably be following your own question!
Jeff
By Dave - September 28, 2017
Hi Tim,
Under: CMS Setup > Section Editors > Your Section > Searching (tab)
You can create a multi-value pulldown by adding [] after the fieldname, eg:
Label Text|fieldname[]|match
And I think you're right that "query" type searches should show as a text field.  Try this patch in: /lib/menus/default/list_functions.php
Search for: b_all and REMOVE the line in red:
    if (preg_match("/\b_all_\b/i", $fieldsAsCSV)) { $fieldsAsCSV = __getAllSearchableFieldsAsCSV($schema); }
    if (!$searchType) { $searchType = 'query'; }
Then add the code in BLUE:
    // figure out "displayAs" search field type
    if (!$displayAs) {
      $displayAs = 'textfield'; // default search field type
      if (count($fieldnames) == 1 && in_array($searchType, ['', 'match'])) { // if single field
        $fieldName   = $fieldnames[0];
        $fieldSchema = @$schema[ trim($fieldName, '[]') ];
        if      ($fieldName           == 'hidden')   { $displayAs = 'checkbox'; }
        else if ($fieldSchema['type'] == 'checkbox') { $displayAs = 'checkbox'; }
        else if ($fieldSchema['type'] == 'list')     { $displayAs = 'dropdown'; }
    $searchRows[] = array($label, $fieldnames, $displayAs, $searchType);
Once you do that you should get a search field with this that allows you to do -not -this searches.
Label Text|fieldname|query
Let me know if that works for you!
Thanks Dave.
That Multi-select works great.  I'll try the patch shortly.
Hey Dave.
I think it's working, but as the "type" field is a list, the values are the num rather than the label...
Not urgent now, as the multi-select works.  But happy to keep going if your perfectionist side kicks in :)
Hmm, yea that is the way they're stored.  We'd have to do some more work to be able to search on the labels.
