Sort foreach loop to display records with uploads first
4 posts by 4 authors in: Forums > CMS Builder
Last Post: November 30, 2017   (RSS)
By Mikey - November 30, 2017
Anyone have any suggestions on how to sort records to show those records with uploads first, followed by other records without uploads? I can't use "drag sort" within the CMS.
Is it possible to sort upon // Load records from menu ? Similar to what's shown below?
  // load records from 'menu'
  list($menuRecords, $menuMetaData) = getRecords(array(
    'tableName'   => 'menu',
    'sort'        => 'uploads',
    'loadUploads' => true,
    'allowSearch' => false,
<?php header('Content-type: text/html; charset=utf-8'); ?>
  // load viewer library
  $libraryPath = 'cmsb/lib/viewer_functions.php';
  $dirsToCheck = array('/home/directory/html/','','../','../../','../../../');
  foreach ($dirsToCheck as $dir) { if (@include_once("$dir$libraryPath")) { break; }}
  if (!function_exists('getRecords')) { die("Couldn't load viewer library, check filepath in sourcecode."); }
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
 <head>
  <title></title>
  <meta http-equiv="Content-Type" content="text/html;charset=UTF-8" />
 </head>
<body>
    <h1>Menu</h1>
<?php foreach ($menuRecords as $record): ?>
<?php if ($record['photo']): ?>
      <h1><a href="<?php echo $record['_link'] ?>"><?php echo htmlencode($record['name']) ?></a></h1>
      <?php echo $record['content']; ?><br/>
      Price: $<?php echo htmlencode($record['price']) ?><br/>
        <?php foreach ($record['photo'] as $index => $upload): ?>
              <img src="<?php echo htmlencode($upload['thumbUrlPath3']) ?>" alt="<?php echo htmlencode($upload['info1']) ?>" />
          </a>
        <?php endforeach ?>
<?php else: ?>
<?php endif; ?>
        <hr/>
<?php endforeach ?>
<?php echo poweredByHTML(); ?>
</body>
</html>
Thanks Zicky
By Toledoh - November 30, 2017 - edited: November 30, 2017
Could you just do 2 loops?
Show records with images in the order set via CMSB
<?php endif; ?>
<?php endforeach ?>
<?php if (!$record['photo']): ?>
Show records with NO images in the order set via CMSB
<?php endif; ?>
<?php endforeach ?>
By leo - November 30, 2017
Hi Zicky,
An easy solution will be using usort() to specify how you want the array to be sorted. You can check the manual here for more information: http://php.net/manual/en/function.usort.php
But basically the code might be something like this:
// sort array
usort($menuRecords, 'sortByUploads');
// sort function
function sortByUploads($prev, $next){
  if(!empty($prev['photo']) && empty($next['photo'])){
    // $prev has higher priority then $next
    return -1;
  else if(empty($prev['photo']) && !empty($next['photo'])){
    // $next has higher priority then $prev
    return 1;
  else{
    // $prev and $next have the same priority
    return 0;
Hope this helps and let me know if you have any questions!
Leo - PHP Programmer (in training)
