Error with PHP 7.4?
10 posts by 4 authors in: Forums > CMS Builder
Last Post: April 9, 2020   (RSS)
By zaba - March 25, 2020
#77 - E_NOTICE: Trying to access array offset on value of type bool
/xxxxxxx/cmsb/lib/menus/header_functions.php (line 167)
http://xxxxxxxxxx/cmsb/admin.php?menu=main_menu
#0 _errorlog_logErrorRecord() called at [/xxxxxx/cmsb/lib/errorlog_functions.php:62]
#1 _errorlog_catchRuntimeErrors() called at [/xxxxxx/cmsb/lib/menus/header_functions.php:167]
#2 _userHasMenuAccess() called at [/xxxxxx/cmsb/lib/menus/header_functions.php:26]
#3 getMenuLinks() called at [/xxxxxx/cmsb/lib/menus/header.php:9]
#4 include() called at [/xxxxxx/cmsb/lib/admin_functions.php:543]
#5 adminUI_header() called at [/xxxxxx/cmsb/lib/admin_functions.php:519]
#6 adminUI() called at [/xxxxxx/cmsb/lib/menus/login.php:42]
#7 include() called at [/xxxxxx/cmsb/lib/admin_functions.php:442]
#8 showInterface() called at [/xxxxxx/cmsb/lib/admin_functions.php:77]
#9 adminLoginMenu() called at [/xxxxxx/cmsb/admin.php:35]
Array
[logType] => runtime
[errno] => 8
[errstr] => Trying to access array offset on value of type bool
[errfile] => /xxxxxx/public_html/cmsb/lib/menus/header_functions.php
[errline] => 167
[errcontext] => *** in symbol table field above ***
By daniel - March 31, 2020
Hi Zaba,
Thanks for this report! We haven't yet fully tested CMSB with PHP 7.4 so you may encounter some issues when using that version. To help me track down the issue, could you let me know which version of CMSB you're using?
By zaba - March 31, 2020
The latest version of CMSB. I was able to change to 7.3 and the problem went away.
By daniel - April 3, 2020
Hi Zaba,
Have you made any customizations to the file /cmsb/lib/menus/header_functions.php? In the latest version of CMSB the line indicated in your error message (line 167) is part of a comment section, and so shouldn't be producing any sort of error. If this file has been customized or if you're unsure, could you attach that file so I can properly see what the error message is pointing to?
By zaba - April 4, 2020
It was a new host, the only thing I installed was cmsb, nothing else. A clean installation from a fresh copy. I may have time next week to set everything up again on a new clean account. and replucate the issue on 7.4. I can then pass on administrator access ftp access etc if you would like to investigate. do you have an email address to send details. I think this is likely the only way to investigate this issue properly.
By daniel - April 6, 2020
Hi Zaba,
If you send a 2nd level support request with the access details (https://www.interactivetools.com/support/request/) we will take a look. Thanks for helping us troubleshoot this further!
By daniel - April 8, 2020
Hi all,
Just to follow up with my findings from the support ticket, on a fresh install the error was being reported on Line 177, which is slightly different from the original error reported in this thread and did point to the cause of the issue. There is now a fix for this error which will be released in the next official release of CMSB; in the meantime, we recommend sticking with PHP 7.3 if possible.
By gkornbluth - April 8, 2020
Daniel,
Thanks for the hard work.
By zaba - April 9, 2020
Thank you Daniel. Fortunately most (shared) hosts have the option to simply change php version without any problem.
