Erase button in single record
28 posts by 5 authors in: Forums > CMS Builder
Last Post: January 7, 2021   (RSS)
By Deborah - January 7, 2021
Djulia, thanks for sharing this plugin!
By Djulia - January 7, 2021 - edited: January 7, 2021
Deborah, I'm glad it's helpful. If you want to limit the remove to the single sections, you can use this version.
Djulia
By Deborah - January 7, 2021 - edited: January 7, 2021
Djulia,
I appreciate you sending the alternate version - that is the preferred method for my usage.
It appears to work, but unfortunately this version throws two errors upon activation or whenever the Plugins page is visited.
1) Undefined index: menuType in /home/xxx/public_html/cms/plugins/erase-buttons-right.php on line 15
2) Warning: Cannot modify header information - headers already sent by (output started at /home/xxx/public_html/cms/plugins/erase-buttons-right.php:15) in /home/xxx/public_html/cms/lib/menus/header.php on line 4
I'm not requesting that you work on this for me - just wanted to post my results.
Thanks again.
Deborah
Oops! Can you test this version? Thanks!
erase-buttons-right.php 1K
The new version works perfectly! Thanks again, Djulia.
Hi Deborah, Djulia, and Mercer Design
I'm assuming that this a V3.54 issue? I see it an erase button in V3.54 in single record sections,  but I don't see an erase button in a site with V3.50 (or am I looking in the wrong place)
Jerry, I think the erase button was added in v3.52 or 3.53. I don't see it on my older installs.
