Error when creating a List Page with Code Generator
I am trying to create a List Page with the Code Generator, and I get the following message when I run the URL of the page (../section-list.php):
Fatal error: There was an error creating the list field 'new_owner'.
MySQL Error: You have an error in your SQL syntax;
check the manual that corresponds to your MariaDB server version
for the right syntax to use near 'd code on line 3 ' ORDER BY fullname'
at line 3 in /var/www/vhosts/vascularregistry.gr/httpdocs/registry/lib/schema_functions.php
on line 410
However, if I login into the CMSB, it works fine, and the content of the list page appears.
Any ideas on how to carry on?
Kind regards,
Andreas Lazaris
By daniel - October 10, 2022
Hi Andreas,
It looks like this is being triggered by an advanced list field, possibly due to an incorrect MySQL query. Can you check the list options for the "new_owner" field? If it's set up to generate the list from a MySQL query, that is probably generating the error. Feel free to copy the query here and I can try to troubleshoot the issue.
Hi Daniel
The list options for the "new_owner_ field are:
SELECT num, CONCAT_WS(", ", fullname, firstname)
FROM `<?php echo $TABLE_PREFIX ?>accounts`
WHERE hospital='<?php echo $CURRENT_USER['hospital'] ; ?>'
ORDER BY fullname
I changed that to a simple list, but the problem still exists. The new_owner field Let me note again that the problem disappears when I have logged into the CMSB and run the URL.
Thanks for your assistance. Regards,
Andreas
Hi Daniel
It does not work both in logged in and logged out users. The following message appears.
MySQL Error: You have an error in your SQL syntax; check the manual that corresponds to
your MariaDB server version for the right syntax to use
near 'global $CURRENT_USER; SELECT num, CONCAT_WS(", ", fullname, firstname) FROM `...'
at line 1 in /var/www/vhosts/vascularregistry.gr/httpdocs/registry/lib/schema_functions.php on line 410
Also, I cannot open the section itself. The above fatal error also appears.
Regards,
Andreas
By daniel - October 11, 2022
Hi Andreas,
Apologies, try this instead:
<?php global $CURRENT_USER; ?>
ORDER BY fullname
Hi Daniel
Sorry to say, but there still come up with the same message
your MariaDB server version for the right syntax to use near 'd code
on line 4 ' ORDER BY fullname' at line 3 in
Regards,
Andreas
By Dave - October 12, 2022
Hi Andreas,
It looks like what is happening is that something in the PHP code is throwing an error which is interfering with the SQL query.
If you like you can fill out a 2nd level support request here and we can take a look and debug that for you:
https://www.interactivetools.com/support/request/
Hi David
Thank you very much for your help
In order to run properly I had to downgrade the PHP version from 7.4 to 7.3
(https://www.interactivetools.com/forum/forum-posts.php?postNum=2244577#post2244577)
Kind regards,
Andreas
By Dave - October 17, 2022
Hi Andreas,
Ok, great.  Glad it's working! :-)
