Photos with captions
Last Post: June 13, 2012   (RSS)
I know that it's easy to add photos and display them with a caption by having an upload field. However, is it possible to import a photo in the midst of text - with a wysiwyg field - and have a caption underneath? Adding the picture wherever I want isn't a problem; having a caption under it is.
For a start, I don't see anywhere that I can type in a caption in CMSB. I could use a two-row table, but that's a bit of a cumbersome solution for my client.
Here's an example of the type of thing I'm trying to achieve, although this isn't a CMSB site: www.liberationgateway.com/tinfo_dr.php. And this is a design visual for the site that will be built around CMSB: www.commonsensedesign.net/extranet/globalmedelite/visuals/05-treatments-ct-overview-01a.shtml.
Nigel Gordijk
Common Sense Design: User-focused Web design
Tel: 001 519 342 5348 | Web: www.commonsensedesign.net
Re: [NigelGordijk] Photos with captions
By Damon - June 13, 2012 - edited: June 13, 2012
Hi Nigel,
I'm looking into the template plugin with TinyMCE:
http://www.tinymce.com/wiki.php/Plugin:template
This allows you to have predefined snippets of code to insert in the WYSIWYG editor.
Try it out on the demo here:
http://www.tinymce.com/tryit/full.php
You could use this to insert a default image and caption (with inline styling or classes) and then have the user replace the image/caption with what they want.
Does this sound like a workable solution?
template_button.png 36K
By Jason - June 13, 2012
Hi Nigel,
TinyMCE is the wysiwyg editor that comes with CMS Builder. It looks like this is a matter of getting that plugin from them, and then integrating it into wywiwyg.php.
If you need any help with this, please email consulting@interactivetools.com and we can go over some options.
Re: [Jason] Photos with captions
Thanks, Jason. I'm not at the development stage yet - still working on the design - but I'll be in touch when the time comes.
Nigel Gordijk
