'where' syntax problem in opened emails test
11 posts by 2 authors in: Forums > CMS Builder
Last Post: November 25, 2012   (RSS)
I’m trying to implement a test for open emails and I’ve come up with a syntax issue.
I’ve embedded this <img> tag in my email message:
<?php $recnum = $record['num'] ?>
<img src='http://www.artistsofpalmbeachcounty.org/open.php?$recnum&amp;opened=1&amp;email=$the_to&amp;project_title=$where' height='1' width='1' alt='' />
which renders the following in the source code of the received email:
<img src='http://www.artistsofpalmbeachcounty.org/open.php?1&amp;opened=1&amp;email=jerry@jkwebdesigns.com&amp;project_title=Test Exhibition' height='1' width='1' alt='' />
open.php has the following code to update the value of a field called 'opened' when the email is opened:
$libraryPath = 'cmsAdmin/lib/viewer_functions.php';
$dirsToCheck = array('/hsphere/local/home/apbcweb/artistsofpalmbeachcounty.org/','','../','../../','../../../');
mysql_query("UPDATE {$TABLE_PREFIX}exhibition_email_test SET opened = '1' ");
mysql_query($query) or die("MySQL Error:<br/>\n". htmlspecialchars(mysql_error()) . "\n");
$userNum = mysql_insert_id();
exit;
Right now, when an email is opened, all of the ‘exhibition_email_test records’ ‘opened’ field values get updated to 1.
I know that I need a ‘where’ in the update code to limit the update to only those records where the record number and the project_title match those which were passed in the URL, but I can’t seem to get the code correct.
Hope someone can help.
Re: [gkornbluth] 'where' syntax problem in opened emails test
By Dave - November 6, 2012
I'm coding blind, but try this.
Instead of outputting this: open.php?$recnum&...
output this: open.php?num=$recnum& (It's easier to get at from PHP).
Then replace this:
With this:
$numAsInt = int_val( @$_GET['num'] );
$query = "UPDATE {$TABLE_PREFIX}exhibition_email_test SET opened = '1' WHERE num = $numAsInt";
You need to always escape or sanitize user input to prevent hackers from tricking the script into running their own MySQL. Instead of calling mysql_real_escape_string() or a related function I called int_val() which forces the value to be a number and accomplishes the same thing.
Also, since the record number should be a unique identifier for the record we don't need to check for equality on the title. Which is good because even if you change your record title in the time between sending out the newsletter and when the script is called everything will still work (since the record number doesn't change).
Also, If you want to prevent your script from outputting a broken image tag (will show up in some browsers) you can put this just before the exit;
header('Content-Type: image/gif');
echo base64_decode('R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7'); // 1x1 transparent gif
exit;
As I said, I'm coding blind so the code might need a bit of adjustments but should be a lot closer. Let me know how it goes. Cheers!
Re: [Dave] 'where' syntax problem in opened emails test
Thanks for taking the time to respond to this.
The ‘opened field’ doesn’t update at all now, but I’m sure it’s really close.
The code that calls the blank image is now <img src='http://www.artistsofpalmbeachcounty.org/open.php?num=$recnum&amp;opened=1&amp;email=$the_to&amp;project_title=$where' height='1' width='1' alt='' />
And the rendered code in the email source that's passed to open.php is now:
<img src='http://www.artistsofpalmbeachcounty.org/open.php?num=1&amp;opened=1&amp;email=jerry@jkwebdesigns.com&amp;project_title=Test Exhibition' height='1' width='1' alt='' />
Here’s the current code in open.php
//Dave's first suggestion
exit;
The “opened’ field in the exhibition_email_test editor is a checkbox.
I’ve attached both the open.php and the exhibition_mail_test1.php files in case something jumps out.
By Dave - November 7, 2012
The next step in debugging something like this is to try and reduce the problem area. So for example we can copy and paste the open.php URL into the browser and add some code to output the values from $_GET or the query we're generating. Then we can determine if the problem is with that component or with something else.
When I do that with this url:
http://www.artistsofpalmbeachcounty.org/open.php?num=1&opened=1&email=jerry@jkwebdesigns.com&project_title=Test%20Exhibition
I get this error:
Fatal error: Call to undefined function int_val() in /hsphere/.../open.php on line 12
Which indicates there was a typo in my (blind) coding! Try intval instead of int_val and then reload that page and see if you get any errors. And if needed you can use print_r($_GET); to see what variables are being received by the script.
Looks like intval was the issue...
As always and again... Thanks for your help.
I probably should try to get this working myself, but the page is live and I really don't want to mess it up.
I need to reset the updatedDate to reflect the time when the email was opened, which I assume would require inserting:updatedDate = NOW() into the code below, but I'm not sure how to insert it correctly.
Existing Code:<?php
$numAsInt = intval( @$_GET['num'] );
$query = "UPDATE {$TABLE_PREFIX}client_uploads SET opened = '1' WHERE num = $numAsInt";
exit;
Thanks Dave,
I feel much more secure about changing the code now.
Hi Dave et al.,
Inserting the following blank image tag in my page now succeeds in changing the ‘opened’ field record of those recipients who opened emails from 0 to 1.
<img src='http://www.artistsofpalmbeachcounty.org/exhibition_email_open.php?num=$recnum' height='1' width='1' alt='' />
However, since not everyone has enabled images in their emails, there is a percentage of recipients who on opening their email, don’t reset the ‘opened’ field.
Based on an idea I found, which suggested that some of these recipients emails would work more consistently to a request for a sound file, I put together the following in an HTML document, which works and resets the ‘opened’ field in record #2 :
<head>
<script language="javascript" type="text/javascript">
function playSound(soundfile) {
document.getElementById("hiddenspan").innerHTML=
"<embed src='http://www.artistsofpalmbeachcounty.org/exhibition_email_open2.php?num=2' style='width:0;height:0;' autostart='true' loop='false'/>";
</script>
</head>
<body onload="playSound();">
<span id="hiddenspan"></span>
</body>
When I try to insert this in the email code of my page, it doesn’t work, and I don’t know whether the issue is related to ATT mail, or more likely there’s a mistake in the code syntax (which begins around line 457 in the attached).
If anyone has an idea how to make this work, or has accomplished this in some other way, I hope you’ll pass it on.
By Dave - November 24, 2012
That's interesting, I haven't heard about that one yet. Sounds like facebook is using it with the bgsound tag:
http://pandodaily.com/2012/03/06/facebook-knows-when-you-open-their-emails-how-creepy-silent-sounds/
In general you want to avoid using <head> content and javascript in emails. Many email clients strip all that out. If email clients allowed javascript then hackers could do all kinds of bad things to the email recipients.
See: http://blog.exacttarget.com/blog/email-design-4/email-design-tip-of-the-week-javascript-in-email
I'd start with a working sound file (not a php) and try sending tags to yourself that actually play the sound. If you get that part working, then just swap it out for the php file that delivers the sound file.
